20th March 2018, 08:50 PM
#61
Yeah nice sure it will come up awesome and should be fun, enjoy. . .
20th March 2018 08:50 PM
24th March 2018, 09:31 PM
#62
SkippyGU
So the series of photos I am about to upload are from the crankshaft. 5 of them are fine one is not. I’ll let you guess which one
Currently own a ZD30 2000 GU patrol with a dead injector pump
![Furious](images/smilies/furious.gif)
about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
24th March 2018, 09:33 PM
#63
SkippyGU
24th March 2018, 09:40 PM
#64
SkippyGU
There is some surface contaminants on the others from being in the garage for a while but the damaged one I just took out.
24th March 2018, 09:51 PM
#65
Ooh ouch. . .
24th March 2018, 10:05 PM
#66
SkippyGU
![](http://www.nissanpatrol.com.au/forums/images/imported/2018/03/237.jpg)
The good one
![](http://www.nissanpatrol.com.au/forums/images/imported/2018/03/238.jpg)
The shit one
24th March 2018, 10:57 PM
#67
SkippyGU
Do you think they could save the crank shaft? Polish it out
25th March 2018, 07:22 AM
#68
Yeah bugger bet your glad it's getting a rebuild now. Had the bearing spun on the journal or just buggered? Expect it's a result of low oil or lack of oil changes most likely ? ? Looks fairly substantial, machine shop will know once it's measured or might have to be ground to see how much needs to be taken off to get it good again. Not sure what over size the bearings go up to will determine the repaiability.
JackCollo (25th March 2018)
25th March 2018, 04:17 PM
#69
SkippyGU
Build time
I think that some debris or something had gotten into the motor and in the journal because they were in the right spot.
Yeah hopefully it can be repaired
Will I need o/s or u/s Conrod bearings?
25th March 2018, 09:57 PM
#70
SkippyGU
Build time
Has anyone had any dealings with crankshaft rebuilders in Blackburn thinking about giving them a call but didn’t wanna waste my time. Open to all opinions.
