Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 92
Thread: Build time
  1. #21
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Well mark I’d be stupid not to take up that offer but don’t worry there will be a bottle of jack in it for you
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  2. #22
    22 Post(s)
    Quote Originally Posted by JackCollo View Post
    Yeah I’m looking for a lot of low down grunt.
    Something you wont even remotely come close too with an off the shelf 3076
    96 GQ coil/Cab
    08 G6eT
  3. #23
    331 Post(s)
    Hey mate i would seriously coincider Borg Warner for turbo, EFR 6758 is a good size. If your after power and want to future proof it in case you want to tweak it up further down the track i would go for 12mm pump.
    Not sure about high flow injectors think it's more of a wankey catch phrase, more depends I the pressure they are set to crack at which should be done with a tune. Not sure on high flow water pump either mine has a standard one and seems fine.
    Personally prefer front mount intercooler and are a huge amount cheaper that a CC one too. High flow oil pump wouldn't have a clue in that one but would assume standard would be fine depending on how crazy yoy want to go I guess. Also need to think about what you want it for too really, how much power you really need versus reliability / drivrability etc. . .
    I have this Borg Warner on my GUIV running 28psi all day. So impressed with the output and torque curve and know it's not even working hard in my car.
    Um just about to fit a 12mm UFI pump and front mount cooler and 4" snorkel. Can't wait t o unlock this thing.
  4. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    JackCollo (9th March 2018), mudski (8th March 2018)
  5. #24
    Dec 2016
    Yeah it sounds like what I’m looking for in the truck.
    Oh please let me know how that goes I’d be really interested in knowing.
  6. #25
    Dec 2016
    Also does anyone know the main front pulley nut size for the gq td42 i can’t figure out. And it’s driving me nuts
  7. #26
    22 Post(s)
    41mm for silver top, 55mm for the rest
    96 GQ coil/Cab
    08 G6eT
  8. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    JackCollo (10th March 2018), MudRunnerTD (10th March 2018)
  9. #27
    Dec 2016
    Champion thanks beneboy
    Any other recommendations for what I should do the motor while rebuilding? Heard good things about multi angle valve grinds
  10. #28
    22 Post(s)
    Everything I have been prepared to discuss is in your other thread. I'd reread it.
    96 GQ coil/Cab
    08 G6eT
  11. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  12. #29
    Dec 2016
    All good thanks Ben-e-boy
    I’ll use the info from that but make this the new thread for people to follow for my build
  13. #30
    Dec 2016
    Anyone got any helpful hints removing the main pulley nut
