Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Aircon Idle / Adjustment question TD42Ti
    469 Post(s)
    @mudski
    Does this look like the vacuum doodah like on hours ?
    I found that... Has a positive and negative .
    And has a vacuum line coming directly from the vacuum pump. And an outgoing vacuum line going to a diaphram under the injector pump but it's hard to tell whether it does anything.
    Would this be it ??
    Yeah thats the bit mate. I removed mine totally.
    Hodge (20th February 2018)
  3. #12
    Jan 2018
    Hodge if you still needing help I can explain.
    There is an actuator below the two throttle cables. Its mounted by two 10 mm bolts. The front of the actuator has a L shaped rod. When the aircon kicks in the rod hooks onto the throttle cable plate or what ever its called lol
    - The actuator can be adjusted two ways. Loosen the two 100m bolts and you can rotate the actuator so rod sits further away from throttle cable plate or closer. Clearly closer will be higher idle (Lower idle will be anti clockwise)
    - The second way is an 8mm lock nut on the rear of the actuator . Loosen it and then adjust the screw out at the end with a flat head. You can see a notch for the flat head. I found using a long flat head is much easier as its tight there.
    The first way is for a coarse adjustment
    The second way is for fine adjustment
    The funny thing is I been playing with it too as I just got my car Dynotuned two days ago. I never knew when they turned up the base fuel it increases idle too.
    They did adjust for me but I wasnt happy. I always want perfection.
    Now if you find you run out of adjustment to keep the aircon lower you can either take the actuator off by undoing the two 10mm bolts and drill the adjusting holes bigger or bend the rod back further away from the throttle cable.
    This mod doesnt affect anything else as its essentially just moving the rod away further.
    Will make sense when you look at the actuator. Very straight foward.
  4. The Following User Says Thank You to drgtr For This Useful Post:
    Hodge (22nd February 2018)
  5. #13
    Jan 2018
    You can see the the aircon actuator below the two throttle cables. Its white. Has the lock but and adjusting screw (for fine adjustment) Thats the whole actuator. mounted on side of injector pump via 2 x10mm bolts WP_20140726_001[1].jpg
  6. The Following 2 Users Say Thank You to drgtr For This Useful Post:
    Hodge (22nd February 2018), mudski (22nd February 2018)
  7. #14
    176 Post(s)
    Quote Originally Posted by drgtr View Post
    Thats awesome !! Thanks a lot mate.
    I did see that actuator.... Its where a vacuum hose goes from that controller i disconnected earlier...
    I will now go and play around with it !!
    469 Post(s)
    yeah sweet. I assumed otherwise. My pump does't even the second lever for the a/c cable. Just had a vac line straight into the top of the pump.
  9. #16
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Mark, if you still have it, I'm chasing one of those vacuum switches. The auto trans makes the idle drop too much.
    John
  10. #17
    469 Post(s)
    I think i do mate. Remind me in a few days if you dont here from me and I'll rummage through my stuff.
    jff45 (27th February 2018)
