Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Cheetah Outreach
No... as prev posted... TD42 only from 99 to 02
Pic of the old v new 5th gear with the extended spline
http://grantm.customer.netspace.net.au/5th4.jpg
dom14 (18th January 2018)
There is good pics floating around showing the changes. Potentially on the other patrol site. I will endeavour to get some pics if I get my old gearbox back from the mechanic.
The problem boxes I believe were early TD42t/ZD30 GU's up till some stage in '02.
Didnt see this before my previous response.
Yep thats one of the good pics I mentioned. They have also increased the length of the spline on the main shaft. Massive overall increase in contact surface area between the shaft and gear.
So i ended up getting a 2nd hand 3L crd gearbox from patrol-a-part. Only had 77k kms I believe. All in and installed and I am back on the road.
mudski (9th February 2018)
I'll check mate. Good advise. I had to remove the engine mounts and drop the engine onto the chassis mounts to do it myself last time I had it out.
