Page 820 of 1056 FirstFirst ... 320720770810818819820821822830870920 ... LastLast
Results 8,191 to 8,200 of 10559
  1. #8191
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Thanks mate.
    Kinda thought that's the going price.
    Unless you wanna do a mudski....
    Nah, for about the same $$ and rwkw I'll prefer to listen to a v8.
  4. The Following User Says Thank You to jay see For This Useful Post:
    Bacho86 (26th January 2018)
  5. #8193
    175 Post(s)
    @mudski has done the right thing.
    If I was doing a conversion , I'd get the motor a tad spiced up while it's out on the bench.
    I love listening to that turbo out of his car ... Even just when the motor starts , the whistle rising up to idle is just phenomelan.
    And driving behind it seeing the car just waltzing around at even slightest squirt of throttle is amazing. I got some dash cam footage.
    All this while I'm in my tractor slug digging for lower gears lol.
  6. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Bacho86 (26th January 2018), jay see (26th January 2018)
  7. #8194
    [/QUOTE
    I love listening to that turbo out of his car ... Even just when the motor starts , the whistle rising up to idle is just phenomelan[/QUOTE]
    If I had a blank cheque I wouldn't spice it up a tad I'll do alot. Unfortunately I don't.
    As for the whistle, what about a whistling Turboed Ls. Now that would be nice..
    I wish I had that blank cheque.
  8. The Following User Says Thank You to jay see For This Useful Post:
    Hodge (25th January 2018)
  9. #8195
    196 Post(s)
    Finished off the remainder of all my tasks except the antenna replacement.
    1) completed the Endless air brackets and ran the system, but not generating pressure - so back to endless air about that - suspect it needs to run faster with higher belt tension - so I guess this is now NOT finished
    2) mounted the brake compensator plate above rear axle - brakes a lot more evenly now whereas the front was the bias
    3) Mounted the twin ARB Difflock vent valves to allow dumping of moist air at the end of the day - @MB had issues with this on a snow trip last year
    4) finished off the odds and sods with the belly tank and put in 60L - no leaks and fills faster than the main tank, so very happy after hearing all sorts of stories of the belly tank taking 20 mins to fill from others. Transfer pump works well.
    5) fitted the 'bulb' primer as recommended by @Cuppa and others, works well and a lot better than the fuel filter primer pump.
    6) packed up the garage mess, grabbed a beer and jumped in the pool.
  10. #8196
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Gave the CRD a sweetie today, oil change, drained the crap out of CC, greased her behind the ears and gippas in fuel tank for inject - clean as pay back. She is settling in after 2 so months work, full NADS, ECU remap all the good bits & pieces including work on muffler back pressure to give me 21/22 psi max B @1800RPM, nice spool /egts and of course: 10.2 l/100kms (mix driving 20% dirt/70%hwy/10% town) and not just poking around (3.1T not camped up). Read from Ultragauge EM Plus, Max Torque (100% load) 475Nm (ref only) and from 2000RPM. Yet to do dyno check.
    Max B
  11. The Following User Says Thank You to Bidja For This Useful Post:
    PeeBee (26th January 2018)
  12. #8197
    465 Post(s)
    Yeah I love the turbo whistle too. No regrets in what I'd done. But I do love the sound of a nice V8 aswell. I'd whack a supercharger on the V8 though. The whine of a supercharger is just as good as a turbo spooling up.
  13. #8198
    LSA.....
  14. #8199
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Sent the GQ away for injector pump reco, a service and check up and over to get it ready for the cape trip .
  15. The Following 4 Users Say Thank You to GQtdauto For This Useful Post:
    Avo (2nd March 2018), Bidja (2nd March 2018), MB (2nd March 2018), Rossco (1st March 2018)
  16. #8200
    196 Post(s)
    Finished off the radiator water spray bar, modified the aircon fan with a @Cuppa over-ride switch so it can be turned on by itself, relocated the new am/fm radio antenna to get better separation from the other antennas - still don't know if it improved reception - fine in Metro area, crap out in the bush, out of total frustration with the endless air installation, now 'thinking about version 276B', so bought another ARB difflock compressor and swapped this over with the bigger ARB compressor, then located the bigger compressor to where the endless air was to use as tyre compressor only, fixed the hydraulic hose leak - think it was operator error and I didn't do the fitting up correctly - tested winch, all good, maintenance run of the rear electric winch, out and in twice, all good. Time for a rest i believe.
  17. The Following 6 Users Say Thank You to PeeBee For This Useful Post:
    Bidja (2nd March 2018), GQtdauto (3rd March 2018), Hodge (2nd March 2018), MB (2nd March 2018), Winnie (2nd March 2018), Yeti's Beast (9th March 2018)
