Results 1 to 10 of 15
Thread: Radiator replacement cost
    Jan 2018
    Sydney, Australia
    Hi
    I've been meaning to find myself a good mechanic that I trust to give my Patrol a good service (plus future services) and inspect for other problems that might be creeping up.
    Last week I was driving to work and steam suddenly started coming from my bonnet. I pulled over and it seemed to be coming from the radiator. I waited till the engine cooled, added some water to the system and drove the patrol to the closest service centre/mechanic.
    The mechanics first diagnosis was that I'd split a main radiator hose that was difficult to get to. I agreed that he should get a full hose kit and replace everything. He quoted $800 for the work. Seeing as my car was already at the shop, I agreed to it without much research, I just needed it back on the road. He called the next day to say that he'd done a pressure test and the radiator itself is leaking too. The old copper radiator that I had, he said would cost about $1200 and labour would be on top of that. He advised that we could do a cheaper radiator, around $500 worth and that with labour to install it he'd charge a total of $1000. Patrol is running great now, $1800 later.
    Don't get me wrong I liked the mechanic, I thought he was a good bloke but I think it's just diligent to check whether I was charged fairly for the work and the parts. I don't know a great deal about automotive mechanics but seemed to be able to find a Patrol radiator + hose kit for around $400 online. I want to know whether what he charged is about right (I understand he needs to make a living out of it, and the labour essentially had to be charged twice!). If it is, I'll probably continue to use him.
    Paddy
    331 Post(s)
    what year is your Patrol and What engine? Where are you located.
    I recently replaced my Radiator in the GUIV TD42Ti and i think the new one cost me around $450 for a NatRad Copper Radiator and i fitted it myself. I would have expected him to salvage the Brand New coolant and use it again in the car when he dumped it the second time so you should nit have paid twice for that. The system should have been flushed when he did the hoses so it was simply an unbolt, lift out lift in, refill, Bleed and pressure check. seems a bit high to me IMO.
    Jan 2018
    Sydney, Australia
    Hi muddrunner
    It's a 1991 GQ Y60. I don't know how to get more specific than that. Here's picture of the badge under the hood:
    Thanks for the reply. It seems what I dug up was about right. Wish I'd done some research before agreeing to the work.
    Jan 2018
    Sydney, Australia
    In Sydney, by the way.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    You've been shafted for sure imo .
  6. The Following User Says Thank You to GQtdauto For This Useful Post:
    dom14 (20th January 2018)
    331 Post(s)
    Quote Originally Posted by PaddyD View Post
    Hi muddrunner
    Yeah OUCH!! You have been Robbed mate.!! i was thinking you where going to talk about a 2015 with some spiffy sensor or something! a 91 GQ!! you could drop a motor in it for that kind of money!!
    You'd probably find a radiator for $300 and an Hour to swap it over including the cup of coffee and 3 smokes.
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    dom14 (20th January 2018), GQtdauto (15th January 2018)
  9. #7
    $800 for the hose kit and labour is high... the bottom hose just needs the plate removed underneath.
    I would have thought under $200 parts ($120 all hoses 1/2 that for Rad hoses only, flush and coolant) and 3 hours.
    In fairness he couldn't pressure test until he fixed the hose BUT I would have thought a Rad leak would have been spotted during the hose change out.
    $500 is fair for the Rad but $500 labour is high as the GQ Rads come out pretty easy... 2 hours tops
    Soooo... seems like he didn't do you any favours at all for labour charges (two lots of 5 to 6 hunjy)
  10. #8
    North brissy
    $50- $80 for hoses. 5 min to pull the rad out. Flush everything 30 min. Put it back in with new coolant. 15min. 3-400 for a rad. 700 maybe 800 at a stretch.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
    PeeBee (15th January 2018)
  12. #9
    Jan 2018
    Sydney, Australia
    Thanks all for confirming what I had suspected. Pity I had no idea. Best form of retaliation I might be able to muster could be a poor google review but even if I don't at least I can go look for a trustworthy mechanic for the future. That's a terrible amount of money to overcharge.
    I've been looking at this one, any thoughts?
    https://www.totalcare4wd.com.au/
    Paddy
  13. #10
    Legendary dom14's Avatar
    38 Post(s)
    Paddy
    Is yours a diesel, petrol or dual fuel?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
