Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 115
Thread: PWM or MPPT.
  1. #91
    Yep, if all panels are the same Voc (open circuit volts) that idea will work tickety boo
    Well the fixed is 22v and the folding is 22.5v..
    Thats close enough yea??
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Yup good enough both will essentially be 22v
    Sent from my E6653 using Tapatalk
    Lucus30's 1999 GU ST TB45E
  4. The Following 2 Users Say Thank You to lucus30 For This Useful Post:
    BigRAWesty (20th May 2017), Cuppa (19th May 2017)
  5. #93
    Jul 2015
    Camden NSW
    6 Post(s)
    Jay see, if you want a low cost solar reg, capable of handling up to around 170w of solar I doubt you would do better than this one at the price.
    http://www.ebay.com.au/itm/VICTRON-B...26.m2548.l4275
    Note that it comes with a 5 year warranty ..... which says a lot about it’s quality.
    It’s a reg which is well thought of from a well known company with a great attitude. I know a number of folk experimenting with low cost computerised lithium battery management who have found these to be good & reliable regs.
    It also has the ability to connect a battery temperature probe, allowing for temperature compensated charging, which I rate highly in regard to looking after batteries well.
    In terms of quality the difference between this & the Chinese cheapies like the CMPT02 is chalk & cheese...... no comparison.
    Hi Cuppa, Just purchased one of these controllers for my twin folding 80w panels. In the instructions it says to always connect to the battery first so that the controller can recognize the system voltage. Knowing not much about solar gear, does this mean every time I use the panels I need to connect the controller to the battery and then the panels to the controller? Seems at bit of a pain on a portable system with the controller mounted on the rear of a panel.
  6. #94
    Ballarat, Vic
    174 Post(s)
    Quote Originally Posted by bazzaboy View Post
    Not having personally used that specific controller myself I can't be 100% certain, but I would be very surprised if disconnecting the controller from the batteries each time is necessary. I would think that if you leave the controller connected to the batteries it would be ok if you then connect the panels to the controller using an anderson plug ...BUT .... just to be cautious I would suggest that prior to connecting the panels that you have them either covered or just laying face down so their output is restricted to 'not much at all'.
  7. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    bazzaboy (5th January 2018), the evil twin (5th January 2018)
  8. #95
    Just leave it connected to the batteries all the time.
    You can connect/disconnect the panels as often as you like (which is sorta what happens when a cloud passes or the sun goes down).
    If, for whatever reason, you do disconnect the batteries from the controller, reconnect the battery before you reconnect the panels/s.
    The reason isn't actually to do with the batteries it is to do with the load voltage.
    If the controller doesn't know the load is 12 volt equipment it can send overvoltages to whatever you have connected.
  9. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    bazzaboy (5th January 2018), Bidja (5th January 2018)
  10. #96
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Depends how your controller is hooked up to your panels, but if space allows, IMO include a rated isolating switch between solar array and controller (single pole ok here). Handy for for safe PV isolation and testing panel out open circuit.
  11. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    bazzaboy (5th January 2018), GQtdauto (5th January 2018)
  12. #97
    Jul 2015
    Camden NSW
    6 Post(s)
    Thanks Bidja, that's exactly what I will do, permanently mount a rated water proof switch and the controller to the rear of a panel. Saves another removable connection, allows me to isolate the panels, and to connect the controller to the battery first via the Anderson connector.
  13. The Following User Says Thank You to bazzaboy For This Useful Post:
  14. #98
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    @bazzaboy when you say portable panels are you wanting to be able to connect to other vehicles or is it simply so you can move the panels around to catch the sun?
    The best location for this regulator or any regulator for that matter is no where near the panel, mount it as close to your battery as possible. Regulators dont like heat, the sun and the back of panels are great sources of heat. By having the regulator close to battery it increases the effectiveness of the regulator and reduces the voltage drop effects.
    Mine is permanently mounted in the patrol, and my panels are easily connected/disconnected via anderson plug extension lead for portability chasing the sun.
  15. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    bazzaboy (6th January 2018), GQtdauto (5th January 2018)
  16. #99
    Agree 100%... worst place for a Reg is on the Panels due to heat and voltage drop, best place is close to the Batteries as is reasonable.
  17. #100
    Jul 2017
    37 Post(s)
    Agree totally that Regs should be close as possible to the battery bank, also be mindful of the temp range and ventilation of the enclosure that is to accommodate the controller.
