Results 1 to 10 of 14
Thread: Engine Light
    Jan 2018
    Adelaide
    Engine Light
    Hi - wondering if anyone can help with an engine warning light in a 2006 GU patrol.
    Two years ago it came on/off periodically and the vehicle would lose speed. Dealership disconnected water? sensor thinking that would fix it. Came on again and they then believed? it needed a new injector pump after connecting to their computer. As it didnt come on for a few weeks we didnt proceed with the $6000? job - this was 2 years ago - it has probably come on twice in this time but caused no problems.
    It is now doing it again and losing speed etc and am just wondering how you know if it actually needs replacing or what the problem is (when they dont seem sure?) Sensor still disconnected. Can this be checked?
    Fiona
    Perth WA
    63 Post(s)
    Hi mate, may be a good idea to post up an introduction before asking for assistance, just gets everyone on side from the start
  3. The Following User Says Thank You to Woof For This Useful Post:
    fbpatrol (3rd January 2018)
    Jan 2018
    Adelaide
    Ok thankyou - I have done this now
    post count still says 2
    OI and don't mess with the Dog......this one bites
    Legendary happygu's Avatar
    Does it 'fix' itself when you turn the engine off with the key and turn it back on again.
    IE: Is normal power restored?
    Jan 2018
    Adelaide
    Well I filled in the rest of my profile? and am just seeking help with the above problem as my husband is in hospital and I am just after some assistance to sort this. I am sorry if I am not following correct protocol?
    Jan 2018
    Adelaide
    Thanks for reply happygu - sometimes it does fix itself as in for 2 years no real problems but other times it comes on again when restarting.
  10. #9
    Quote Originally Posted by fbpatrol View Post
    I have had the check engine light turn on a couple of times on one of my older Patrols, and it had no effect on the vehicle and the light went out itself - no harm done, and i never worried about it. There are many minor things it could be, from water in the fuel filter, to Turbo slightly Overboosting.
    If it does this and it loses speed it is going into limp mode to protect the engine, but if you can turn it off and the power is restored, it most likely won't harm the engine. It is more dangerous from an operational point of view, as you don't want it to go into limp mode whilst pulling out in an intersection, etc
    You could try disconnecting the battery for 30 min to clear codes - reset the computer, and see if that helps.
    If you want to know what is happening, every time the Check Engine Light comes on, there will be a code logged in the computer associated with that, and there are a few different ways to get this information out of the ECU.
    Firstly, Nissan will be able to diagnose through their testing devices ( $200 - $300 ), secondly, you can short out pins on the OBDII Connector, and a code will flash on the dash that can be interpreted ( $ Free ) and thirdly, you could buy something like a Scanguage/Ultragauge/OBDII Reader ( $ 25 - $200 ), which presents the fault in English - easy to read.
  11. #10
    Jan 2018
    Adelaide
    Thankyou for that information - I will disconnect the battery first off before attempting anything else. Not keen on dealership hooking their computer up again as it seemed to give varying answers and 2 years ago it needed fixing when I dont beleive it did after running basically problem free for another 2 years without spending these thousands of $???? That is my dilema. Thanks again for your help - very appreciated!
