I think now the ones like hodge has now might suit yours better,
you could sell your to GU bigfish if they are suitable, just a thought
Thanks all the same John, now I have them sitting right and the cost of the ally rod and longer bolts they can stay there.
Freighting to WA, it's not really worth the hassles.
Thanks again for the thought though.
G'day John, just a quick check in from the motherland mate. Your beaut chunks of steel have made it through all and are now finally enroute to: http://www.higalv.co.uk/colourgalv/
G'evening John @threedogs mate!
Your beast recovery points kindly purchased are finally back from expensive Scotland Highland Coaters tests old mate :-) image-2467131429.jpg
They're mostly LRover blokes up there but were suitably impressed with your engineering;-)
Hey John hope.your well bud, I need a couple of front recovery points for the GUIV with ARB Deluxe front bar mate. Can yo u pm me a price posted to Lara please.
Legend.
You will need the same ones as I have Darren. It isn't a direct bolt on like other points John makes. There is a metal lip on one of the bull bar's brakets in the way. However, John, threedogs' metal mastery resolved that fairly quickly. I met up with him several times while he took measurements etc... And then built them to suit, supplied together with special washers for load spreading purposes.
I believe the set I have are the only ones of its kind he made. Yours might be the second!
There is a tiny bit of grinding involved too. I have photos at home if need be.
Hey John. Do you make platforms to replace the middle seats in a wagon?
I remember seeing a picture of your car on a thread where you have removed a seat and replaced it with a platform.
Cheers,
Angelo.
Thanks Hodge but I am after a false floor/platform for the middle seats so I can turn it into a two seater. Something I can secure jerry cans, fridge, space cases etc.
I am pretty sure TD has done it to his car.
