Results 1 to 10 of 16
Thread: Gq Vacuum canister tank.
    Advanced mad66's Avatar
    Nov 2017
    Victoria
    I was having a look at the rd28 supp and noticed this tank that I thought might be emission related but turns out to be a vacuum canister. It is not there in my car and some one has fitted an air horn pump. Now I have removed the pump but want to know if it is a vital thing to have. I have heard that it is for brakes and clutch but I am not sure as the car won't be here until next week and want to get a RWC done so want to cover as many things as I can. Pic for attention. Is it ok not to have this installed?
    587 Post(s)
    100% need it mate.
    Some of us need more, low revs no brakes it's a must have!
    Nov 2017
    Victoria
    100% need it mate.
    Thanks mate I will get onto it asap. I didn't think of the low revs part makes scence. Cheers
    197 Post(s)
    WOW, look at all that room under the bonnet!
  5. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    AB (17th December 2017), GQtdauto (17th December 2017), MudRunnerTD (17th December 2017)
    331 Post(s)
    Quote Originally Posted by mad66 View Post
    It is interesting that yours dosent have one yet is drivable. I would suggest it might have been relocated as you will simply have almost NO Clutch and certainly No Brakes. I had a split vac hose on my GQ 9nce and had Zero brakes! I had to pull up with the hand brake and use rescue tape on the pipe.
    I'd say it is there somewhere or a smaller one is there.
    Nov 2017
    Victoria
    Interesting I will have a good look to see. but what I did notice I a few vac lines going nowhere. brakes are good and so is clutch so not sur yet, will get back as soon as I have a good look.
    195 Post(s)
    Yeah agree must be one somewhere else. I had no vac in the clutch the other weekend and was a prick of a thing but no vac to brakes would be defiantly undriveable they would be terrible. . .
    Legendary dom14's Avatar
    38 Post(s)
    Doesn't that make it a little bit unsafe?!!!
    Are there any counter measures built into diesel engines to prevent that from happening on the fly?
    I mean losing brake boost due to loss of vacuum is one thing , but losing brake entirely can be trouble, particularly if the car's moving fast enough.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  10. #9
    331 Post(s)
    It happened to me on the freeway. it wasnt until i was pulling into the service centre to refuel that i realised i have Zero Brakes. change down on the fly then handbrake to a stop worked fine. Emergency braking would have been out of the question though.
    If the OPs car is drivable and has brakes i think there will be a Vac Can somewhere.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    dom14 (18th December 2017)
  12. #10
    331 Post(s)
    So i am in front of the computer now and looking at your pic on the big screen. That canister you have pointed too is a secondary tank. See the smaller tank behind the coolant reservoir mounted to the side wall will be linked into the system and is the Only tank i have on the GQ.
