24th November 2017, 06:21 PM
Td42 missing after new pump
Hi all,
So I fitted brand new genuine zexel injectors and a rebuilt 12mm injector pump.
Took ages to initially start and noticed it was advanced too far so rotated it back to centre of the slot.
The car starts now but runs and idles really rough, under revs it misses pretty badly?
Any thoughts, could it just be timing??
24th November 2017 06:21 PM
24th November 2017, 06:27 PM
baxy
Hi all,
Not an expert but sounds that way , did you get all the air out of the lines ?
Wish you took some pics mate .
25th November 2017, 01:09 AM
yeah, sounds like you are 1 tooth out on the timing
gunna be a bugga, but you will need to take it out again
25th November 2017, 11:17 AM
Ok, checked pump and the teeth definitely line up, a z other side of the mark. Turned the pump further towards the drivers side and it idles perfect but breaks up just off idle. Have cracked all injectors and primer pump is solid??
I'm at a loss and have a trip in 6 days 😩
25th November 2017, 11:29 AM
Might be a job for a diesel mechanic mate , there is adjustment that's sealed but not 100% sure on what it does .
27th November 2017, 06:30 PM
Administrator
Just double checking its lined up like this pic?
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/11/225.jpg)
27th November 2017, 06:32 PM
Administrator
Key pressed in...
I ![](http://www.nissanpatrol.com.au/forums/images/imported/2017/11/226.jpg)
27th November 2017, 06:36 PM
Administrator
Have you got a timing tool?
You really need to have the timing spot on otherwise take it to someone.
