Hi Guys n Gals
I have an 04 3l 5sp ,I also have a long brake pedal 'which is bloody annoying'.
I have had the brake fluid replaced a little better still pedal goes a long way b4 any resistance ,Brakes work great for a 2.5 tonne bus
With 315/65/16 tyres .
I have measured the pedal height 175mm from the carpet clutch is 185mm .
Not much fum when off road going up a steep climb n you jump on the brakes n the pedal almost hits the floor .
What could be the issue ??
Any help will be Great .
Craig
