20th November 2017, 08:32 PM
#11
Winnie
Just a 41mm socket and big breaker bar yeah?
I don't have the budget for a $500 harmonic balancer, is there a way I can test it while it's off?
$75AUD for a harmonic balancer plus shipping out of dubai. Currently 2 in stock.
The Following User Says Thank You to nissannewby For This Useful Post:
dom14 (22nd November 2017)
20th November 2017 08:32 PM
22nd November 2017, 01:27 AM
#12
nissannewby
Why was Winnie thinking it costs $500? Was @Winnie referring to the price of a genuine Nissan one from Nissan dealer?
22nd November 2017, 05:58 AM
#13
The 747
dom14
http://patrolapart.com.au/product/ge...and-na-gu-td42
22nd November 2017, 10:25 AM
#14
Ben isnt talking about that bit although that is incredibly dear. You want the dampener that bolts to it which is what I quoted.
22nd November 2017, 10:26 AM
#15
Winnie
This part is $162aud with 11 in stock plus shipping.
22nd November 2017, 11:44 AM
#16
Just a quick fix for undoing the bolt. I used an impact socket with a breaker bar and a heavy bit of pipe. I wedged the breaker bar and pipe onto the concrete and briefly turned the ignition key to start. It cracked the bolt. This worked on the RB30, but it is a lot smaller than a TB or TD.
To torque the bolt on an auto, place an old V belt on the harmonic balancer and twist it real tight with a bit of strong pipe. Slip a longer bit of pipe through and wedge it onto something solid.
If done right, you should be able to torque the bolt to spec.
The Following User Says Thank You to mudnut For This Useful Post:
22nd November 2017, 04:49 PM
#17
mudnut
I've been doing the undoing and tightening both by putting it into first gear & combining handbrake or brake(lock the brake pedal using a jack) with it as well.
Does that stress the gears too much??!!
I'm thinking, using a rattle gun would also stress the gears(if it's in gears), would it not?
Reason: grammar and missing words, as usual.
22nd November 2017, 04:52 PM
#18
nissannewby
It should come to around $200 with shipping. I think that's a fair price as oppose to over $500 here.
Something's not right for a complete harmonic balancer to cost over five hundred bucks.
22nd November 2017, 06:57 PM
#19
dom14
I thinking, using a rattle gun would also stress the gears(if it's in gears), would it not?
Dunno, and dunno. I would never use a rattle gun on engine parts anyway. Having a manual I just chuck it in gear with the handbrake on and use the ratchet and then the torque wrench.
22nd November 2017, 08:53 PM
#20
mudnut
Yeah, wouldn't use the rattle gun on it either, but I know mechanics do(or at least some of them do when they can squeeze in a rattle gun in there).
The reason I asked 'cos I've never used the cranking method to loosen it, and for some reason felt uncomfortable with it, but I do know most guys use that method without any dramas.
I just felt I'm the only one use the gear lock and breaker bar method to undo it.
