It does @PeeBee
But my charging system is the redarc sbi12.
It does @PeeBee
That's a dual battery solenoid jaysee not a charging system (sbi12).
OK. I'm going to replace the battery, I'm sure that it's dropped a cell.
Came across this
https://www.aussiebatteries.com.au/b...-cycle-battery
Wasn't looking for one that big, but at the price it looks good. Works out at $283 delivered.
I keep seeing people talk about making sure that its the correct weight. All I could find is that the weight is worked out at .3 kg per ah so this should be 42 Kg. It states that it's Approx 37.6 Kg. Is my .3 per ah correct and what are your thoughts on the battery, anyone got one?
I have two aux 105 amp gel cell batteries bloody heavy suckers but not worried about weight so much , the price is cheap for a 140 amp battery.
jay see (20th January 2018)
Thats a good price for AH-per-$ .
I wouldn;t worry about the weight, just make sure if it's going in a under bonnet tray that the tray can handle it.
It's going in the back. I want to reduce the length of one of the draws and stick the battery behind it eventually.
I'm not concerned about the weight, it's what I read to work out if you get what is advertised. Some are sticking a xxxah sticker on it and it's not.
Ordered it earlier today.
Should have it some time next week will report back after I get it in and have given it a run.
Faultless. I was a little concerned so I brought a folding solar panel to keep it topped up, but it handled a weekend trip without a problem. That's a 50l fridge,a few phones and the radio going (also connected to the aux battery)
I think in my build thread there's the install of the battery behind the draw.
I put it on a 240v charger every few months or when I remember..
Yeti's Beast (13th February 2019)
