ITs a feature not a Fault !!!!
Few years back I ended up adding too much grease to those bearings and grease was oozing out of the scrapers.
On top of that I did the stupid thing of applying a thin layers of sealant to the bearing cap shims as well.
One of my axle seals are leaking slowly now and need to be done soon.
A messy but quite DIY'able job as I've been told by MudrunnerTD by his threads.
Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Cheetah Outreach
Drop the lowest one of the bottom swivel bearing bolts and poke a bit of stiff plastic in there. If there is diff oil it should dribble out.
Cheetah Outreach
