12th November 2017, 04:20 PM
#11
if you line up all the spark plugs the leaking cylinder will be more of a washed brown colour than black carbon compared to the rest, the steam from even a small trace of coolant has a vry strong cleaning effect on the carbon that builds on the head/piston
gone to the dark side 2017 vdj 79 dc
12th November 2017 04:20 PM
13th November 2017, 09:08 AM
#12
16th December 2017, 04:48 PM
#13
Red stuff is what happens when you use ethanol blended fuel, like E10 etc. Fucks everything, if you wanna use e10 you must use it in 95 octane blend (read label at pump cause you can get e10 from 89 through to 101 octane at different servos)
Had this issue heaps when e10 first came out, people didn't understand that the car said it was ok but didn't read the fine print as to what blend to use, Replaced many of plugs for engines running rough from it haha
Many people pretty shitty cause they all thought it would be under warranty.
17th December 2017, 06:00 AM
#14
johno90
Probably 'cos ethanol creates more moisture on combustion.
Mine runs on LPG most of the time & I've never used E10, so the above red residue in mine's more likely due
to coolant water getting into the combustion chamber and causing the chemical reaction to produce the red oxide buildup.
I think it's just fine ferric oxide for the most part. The high pressure & high temperature inside the combustion chamber is
ideal to produce that particular oxide of iron.
17th December 2017, 07:46 AM
#15
dom14
It think it's just fine ferric oxide for the most part. The high pressure & high temperature inside the combustion chamber is
Unfortantly thats a complete negative. Without going to deep into the actual chemical science it cant be and never has been red oxide.
Only things that make a plug look like that are leaded fuels, fuel that has ethanol or some of those intank additives you can buy. Fyi fuels these days can have ethanol without advertising. Like bp95 has it but doesnt say unless you get the mdss and read it.
If your interested later on i can do the chemical break down of how it happens ![Smile](images/smilies/smile.png)
The Following User Says Thank You to johno90 For This Useful Post:
dom14 (18th December 2017)
17th December 2017, 07:49 AM
#16
johno90
Oo and if you habe a coolant leak into combustion chamber and burn you will find that it shall actuall clean the plugs. Same deal as water meth and also just pouring water into it when its runnig good old skool way of cleaning out all the carbo etc. (Must do above methed correctly tho please dont stick the garden hose down ur motor)
18th December 2017, 12:48 AM
#17
johno90
Ok, cool thanx.
I would like to believe it was not caused by ethanol in fuel 'cos I have congenital aversion to ethanol added ULP 'cos I think it's bad for conventional old engines like mine(RB30). I've never used 95RON or 98RON. It always has been 91RON or once or twice with 98RON when I was experimenting LPG & 98RON ignition time(to find out if they are closer in terms of ignition timing needs). Leaded fuel is out of question I think 'cos it is no more.
I've been under the impression that it is illegal to sell ethanol added fuel without indicating it at the servo pump. You say otherwise, which got me thinking and worried.
Please do post the break down of the chemical reaction of the red stuff on the spark plugs.
And btw, I've never added any additive into petrol, but dunno whether somebody else added anything, but hope not.
18th December 2017, 12:53 AM
#18
johno90
Yeah, that makes sense.
I've been using only the rust inhibitor in the coolant(no anti freeze) with deminerlized water.
I was once speculating whether that had something to do with the red stuff, but that's also counter intuitive 'cos rust inhibitor should've reduced the claimed "ferric oxide" in my initial argument.
