18th January 2014, 04:21 AM
Need Info for a Zexel pump off Td42 Blacktop also AXT turbo.
I recently bought a Td42 Blacktop with a broken head to do a injection pump swap (have a inline pump). I was told it was a '94 model and it has a Zexel VE type injection pump. I'm trying to get some information about this pump, plunger size and if it can be used for turbo modification without having to send it to the diesel shop. Also what should the crack pressure be for the injectors originally and what should they be set to when torbo'd? I have an AXT water cooled turbine and have been using it for a year now with not so good result because the inline ip can not be tuned to give more fuel. Does anyone know how much boost is safe for this turbine? Thanks in advance and cool greetings from Iceland!
Injestion pump number:
365 J793173
Pump no. 104660 - 4300
Sticker in the front:
16700 50N00
104760 - 4300
18th January 2014 04:21 AM
18th January 2014, 11:27 AM
Patrol Guru
no idea mate but hopefully someone will jump on and be able to help.
GQ Snorkle Lockers front n rear
19th January 2014, 08:58 AM
Been googling around and can't find a webpage where i can see information about Zexel pumps using pump numbers.
20th April 2015, 06:14 PM
i got same probleme here on tunisia i juste changed the original plunger -(6.5mm) too a (7.5mm) and did som stup to fix the gazoil flow !
12th November 2017, 04:21 AM
If you need any part for the ZEXEL pump or diagram, let mi know! I'll send it to you.
The Following User Says Thank You to galme For This Useful Post:
GQtdauto (12th November 2017)
12th November 2017, 07:11 AM
I found it hard to get any real info on this pump or a proper diagram when I replaced the top O rings that were leaking .
