threedogs (23rd November 2016)
@Royce heres what you want to make life easier Imho.
First get the boost set, then you can attempt some of your
other problems
.http://www.ebay.com.au/itm/Nissan-Pa...4AAOSw5cNYLPmR
G'day John, just a quick check in from the motherland mate. Your beaut chunks of steel have made it through all and are now finally enroute to: http://www.higalv.co.uk/colourgalv/
G'evening John @threedogs mate!
Your beast recovery points kindly purchased are finally back from expensive Scotland Highland Coaters tests old mate :-)
They're mostly LRover blokes up there but were suitably impressed with your engineering;-)
Hey John hope.your well bud, I need a couple of front recovery points for the GUIV with ARB Deluxe front bar mate. Can yo u pm me a price posted to Lara please.
Legend.
Do you think the same as Hodges would fit, check his biuld thread sorry its been so long but you know....... @MudRunnerTD
MB (1st January 2018), MudRunnerTD (4th January 2018)
@MudRunnerTD
You will need the same ones as I have Darren. It isn't a direct bolt on like other points John makes. There is a metal lip on one of the bull bar's brakets in the way. However, John, threedogs' metal mastery resolved that fairly quickly. I met up with him several times while he took measurements etc... And then built them to suit, supplied together with special washers for load spreading purposes.
I believe the set I have are the only ones of its kind he made. Yours might be the second!
There is a tiny bit of grinding involved too. I have photos at home if need be.
Hey John. Do you make platforms to replace the middle seats in a wagon?
I remember seeing a picture of your car on a thread where you have removed a seat and replaced it with a platform.
Cheers,
Angelo.
Here you go mate. Mudski sells them here.
http://www.ebay.com.au/itm/Nissan-Pa...-/331374282505
