6th October 2017, 09:23 AM
2002 Di 3ltr fast idle problem
Our GU has just started to idle at 1500 rpm for some reason , have cleaned the maf sensor no change , checked the switch that you can increase the idle when cold and it does nothing at all probably because it's already over idling .
Anybody come across this issue before and how was it fixed ?
6th October 2017 09:23 AM
6th October 2017, 10:04 AM
GQtdauto
Check wireing and plugs to the ECU and also the TPS. Any codes?. Might be worth the old disconnect the battery for 10 mins and reset everything?
6th October 2017, 10:09 AM
Thanks will give it a go .
6th October 2017, 10:37 AM
4bye4
Bugger can't find the pin for the radio , turned the car inside out but it must have been turfed by the missus , so until I can find the code or a cheat for the code might give disconnecting the battery a miss , it's due for a service anyway .
What I did find made me laugh , the old service receipts from the dealer which includes clutch fluid and test clutch operation ,not bad for an auto .
6th October 2017, 04:03 PM
Problem solved by using this strange idea from another site , just let it idle for 5-10 minutes ,mine took 4 minutes then clicked back down to normal revs , restarted and still good , don't know how or why this worked and don't care just happy it's fixed .
The Following User Says Thank You to GQtdauto For This Useful Post:
mudski (6th October 2017)
7th October 2017, 07:05 PM
cant you use a 9v battery connection so you can keep memory
GQtdauto (7th October 2017)
7th October 2017, 07:16 PM
No need now TD , as for the radio pin will cross that bridge when I fall of it .
7th October 2017, 07:43 PM
#8
GQtdauto
Hey mate. I get the same problem when I hit a big pothole or something. The only way I've fixed it is to pull on the accelerator cable at the top of the pedal and instanly drops back to normal. No mechanic has been able to stop it. I just put up with it.
The Following User Says Thank You to Biggsy73 For This Useful Post:
7th October 2017, 08:47 PM
#9
Biggsy73
It's the wife's car so no idea if she hit a pothole , I did try revving it but with all the electrics wasn't game to do too much so lucky I found the idle fix which is still working for now .
