Results 1 to 10 of 11
Thread: GQ Flares
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    GQ Flares
    Alrighty! Need flares for this moneypit of mine.
    Looking at Kut Snake ex The 4wd shed in Bayswater Vic.
    Anyone had dealings with them? Feedback please.
    477 Post(s)
    Yep, MudRunnerTD a while back suggested I go see Phil from 4wd Shed to rebuild my Hi-Mount winch. Very knowledgeable bloke, did a great job, happy customer here mate!
  3. The Following User Says Thank You to MB For This Useful Post:
    Touses (7th September 2017)
    Mar 2016
    Childers QLD
    22 Post(s)
    Nuh! Panel beater says too broad will have to fit neg rims to fill ém.
    Need flares to not much more than 65mm.
    Anybody know of same?
  5. The Following User Says Thank You to Touses For This Useful Post:
    MB (8th September 2017)
  7. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    MB (8th September 2017), Touses (9th September 2017)
  8. #5
    477 Post(s)
    Clunkstar is on the money there mate!
    Alternatively Bunnings has some other dodgey options I've seen done by mates ;-)https://www.bunnings.com.au/search/p...directFrom=Any
    Just don't choose the fence picket style edging as the boys in blue wouldn't appreciate it :-)
  9. The Following 2 Users Say Thank You to MB For This Useful Post:
    Clunk (10th September 2017), Touses (9th September 2017)
  10. #6
    588 Post(s)
    Don't do bunnings flares, I've been there and it's average at best.
    I'm running Bushranger Flexi flares and they look mint!!!
    http://www.bushranger.com.au/flexy_flares.php
  11. The Following 3 Users Say Thank You to AB For This Useful Post:
    MB (10th September 2017), Rossco (9th September 2017), Touses (9th September 2017)
  12. #7
    Mar 2016
    Childers QLD
    22 Post(s)
    Ta for that bloke! Will check these out for sure. Bolt thru guard from underside of flare yes?
  13. #8
    588 Post(s)
    Quote Originally Posted by Touses View Post
    Yep I'm mr paranoid with rust so I drilled the holes primed painted and used stainless pop rivets but bolts would be fine.
    I also wanted max clearance so didn't want bolt heads sticking out either.
    They have a wire hole extrusion on the outer edges of the flares and they supply wire to run through and shape so it holds the shape really good and no sagging.
    Allow a few hours and take your time to shape each flare. It can be frustrating, don't crack the shits and bend the wire lol
    Spray silicone spray down the holes for easy penetration lol
  14. The Following 2 Users Say Thank You to AB For This Useful Post:
    MB (10th September 2017), Touses (10th September 2017)
  15. #9
    477 Post(s)
    Some small/medium fender washers under the rivot heads can help spread the pressure too across the rubber face.
  16. The Following 2 Users Say Thank You to MB For This Useful Post:
    AB (10th September 2017), Touses (11th September 2017)
  17. #10
    588 Post(s)
    Yeah sorry i forgot to mention that, I put small washers to space the load out too.
  18. The Following User Says Thank You to AB For This Useful Post:
