Results 1 to 10 of 14
Thread: Boost control
    Aug 2017
    Wauchope 2446
    Lightbulb Boost control
    Hi all I have a zd30crd and I don't know if I should use a tilix set up or let the ecu control the boost. Do common rails need to be controlled manually?
    475 Post(s)
    Quote Originally Posted by Mick Dagert View Post
    Welcome aboard Mick mate! Not too savvy on electrics or ZD's meself but @bigguwesty when he has time may be able to help, good bloke!
  4. The Following User Says Thank You to MB For This Useful Post:
    Mick Dagert (6th September 2017)
    Aug 2017
    Wauchope 2446
    Cheers bud I need all the help I can get
  6. The Following User Says Thank You to Mick Dagert For This Useful Post:
    MB (6th September 2017)
  7. #4
    Welcome Mick.
    The crd is a lot better than the Di with control.
    But is still woeful..
    Have you done any of the nads setup yet?
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Mick Dagert (7th September 2017)
  9. #5
    Aug 2017
    Wauchope 2446
    Thanks bigguwesty.
    I've done the exhaust, egr blocked and catch can that's all
  10. #6
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Thanks bigguwesty.
    Hello Mick, 2 weeks ago completed install of NADS on my 2008 CRD and it did include manual boost control (Dawes and needle valve in my case). Re: boost control, l had a few initial issues to overcome of which bigguwesty was a great help. Willing to share my experiences in setting boost operation if you have a need. Very pleased in eng performance now. You may have scan tool to assist in clearing fault codes, I have experienced very few but having a scan tool has certainly been beneficial. My EGR plate is at exhaust manifold. Welcome
  11. The Following User Says Thank You to Bidja For This Useful Post:
    Mick Dagert (8th September 2017)
  12. #7
    Aug 2017
    Wauchope 2446
    Thanks Bidja I do have a scan tool and get the error code a couple of times a week. I wander if a tune deletes that code? But I will purchase a kit where is the best place to look?
  13. #8
    Hey Mick.
    You'll probably find that with those mods you may have large amounts of over boost.
    While curzing I was seeing up to 30 plus psi with those mods on the scangauge..
    So yea get onto either a tillix valve or dawes valve. Both do the same thing, I just prefer the design of the tillix that's all.
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Mick Dagert (11th September 2017)
  15. #9
    Jul 2017
    37 Post(s)
    Mick, firstly my learning of NADS has come primarily from reading on this forum and the valued one on one advice provided from select members.
    Note bigguwesty comment re: either type being contenders and check them out.
    Dawes can be acquired from Mudski and he can be contacted via the forum. I installed both the Dawes and needle valve from Mudski and achieved a good result. Certainly would have compared both types if I had knowledge of the 2 options available when I was getting the bits together. Have a read:
    http://www.nissanpatrol.com.au/forum...sing-thru-NADS
    Understand the EGR block causes the fault code coming up and maybe its placement may also have an effect on their occurrence as well of the driving environments city/rural.
  16. The Following User Says Thank You to Bidja For This Useful Post:
  17. #10
    Aug 2017
    Wauchope 2446
    Thanks everyone for the help I will order one asap. Where's the best place to buy pillar pods for a boost gauge?
