Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: Portal Upgrade on GQ Patrol
  1. #31
    197 Post(s)
    Quote Originally Posted by DX grunt View Post
    There used to be a guy on here called portal pat and he did a build. Not sure if he's still on here or not, or his info is still relevant.
    Cant find the link with a search - another thread or tag name perhaps? I have read the Figjam thread but thats a totally different beast all together. Also nother of value to glean re portals apart from them used in the build.
  2. #32
    WA Wheatbelt
    23 Post(s)
    Try going to the individual build for each vehicle. Pretty sure it was quite a few years ago. @Plasnart can u remember?
  3. #33
    North brissy
    197 Post(s)
    Many thanks, will see if AB can get the images up as well
  5. #35
    331 Post(s)
    Yeah thats the one i mentioned in my post above. It would require AB to have access to his account with passwords to get the images. Unfortunately it is likely lost for ever. It was awesome as he fitted them to a basically new car and everything was spotless clean so the pics were awesome.
    There is a couple of other threads on the forum with Portals. I searched Portal Pat and found a few others.
  6. #36
    109 Post(s)
    Yep that one @DX grunt
  7. The Following User Says Thank You to Plasnart For This Useful Post:
    DX grunt (6th September 2017)
  8. #37
    197 Post(s)
    OK, thanks guys. Waiting on Marks 4x4 to ring me back - will advise outcome., Real shame about photobucket though.
  9. #38
    197 Post(s)
    Well, good news and bad unfortunately. GQ Patrols won't get approval to run 35" tyres with portal axles but GU Patrols will. The reason is the VSB 4 rules only allow for current models that have gone thru a 2 stage verification process for larger wheels, which Marks 4x4 did for the GU but never did for the GQ, hence its 33" max for the GQ. If the GU had not gone thru the second stage of testing before the Y62 came out, it also would not have been allowable to fit 35" tyres.
    Everything else is doable and achievable from an engineering certification in Victoria. The clearance rises under the diff bowl to 125mm instead of 150mm, which I think is a small compromise. Wheels will stick outside the guards from where they are now by 100-120mm, and the wheels supplied at neg 60 offset and landcruiser pattern - they no longer make a nissan pattern portal.
    MB (7th September 2017)
  11. #39
    477 Post(s)
    Was chatting with AB yesterday Phil mate about our Vic boys in blue always pulling over cars/trucks that appear illegally modified. When folks spend big coin getting it done legally shouldn't the mods be officially listed against their plate numbers when they look up on their onboard system. Those 'Sheriff' road stops and auto cameras out your way seem to efficiently pull over outstanding vehicle owners warrants/fines listed against plates. Surely Vic-Roads could/should easily add to a national system that say your truck is an approved 6.5L Brunswick with Marks Adaptor portals and not waste everybody's time and money investigating roadside ;-)
  12. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (7th September 2017)
  13. #40
    109 Post(s)
    You are talking about Vicroads/govt department MB. Can you please explain where sense and sensibility apply here?
  14. The Following 3 Users Say Thank You to Plasnart For This Useful Post:
    MB (7th September 2017), PeeBee (7th September 2017), Rossco (7th September 2017)
