31st July 2017, 09:23 PM
#781
Holidays, did the Ghan from Darwin to Adelaide, and other stuff as well.
Now primed to get on with "other" things.
The Following User Says Thank You to poindexter For This Useful Post:
31st July 2017 09:23 PM
26th August 2017, 05:27 PM
#782
The Following User Says Thank You to MB For This Useful Post:
PeeBee (26th August 2017)
26th August 2017, 06:22 PM
#783
Swapped the two in-line Ryco filters today, replaced them with a single CAV glass bowl type. had to make a bracket to mount it, plus also a stone shield as it sits close to the floor but in front of the rear axle. Total install took about 4 hrs, but pre prime the filter first as the lift pump cannot pull thru two filters and neither will the booster pump suck fuel either. Frustrating next 3 hrs to resolve this 'little issue', but all good now, fitted with the 100W heater band as well, ready for the next snow trip!!! Oh plus the 1 hr to clean up all the diesel I dropped on the driveway. Mrs PeeBee not happy as she wanted a driver today to go - yep - cushion shopping - something really wrong with that woman I reckon.
The Following 3 Users Say Thank You to PeeBee For This Useful Post:
MB (26th August 2017), Rossco (26th August 2017), Winnie (26th August 2017)
26th August 2017, 08:03 PM
#784
Good stuff Phil, will surely work a treat up there mate!
I reckon I'll need to go back to a leafy ute or somehow GVM upgrade the coily if you keep inspiring me with cracka idea add ons :-)
26th August 2017, 08:43 PM
#785
MB
Just crank up the air pressure in those airbags, heaps of capacity for future 'essentials'
26th August 2017, 08:51 PM
#786
MB
26th August 2017, 08:57 PM
#787
I'm thinking you should kindly when time permits mate create a thread for snow proofing cars etc.. I'm sure our Northern Hemisphere members can also add true valuable life saving tips etc... I actually felt very lucky that my truck kept running on that weekend but will surely come undone oneday soon! My concerns were so much that as you know I packed up basecamp daily and carried everything needed even on the supposedly 2-3 hr sight seeing trips out just in case :-)
26th August 2017, 09:09 PM
#788
Ok will give that some thought. Our conditions are probably a lot milder than our northern hemisphere buddies, so think they will value add the most. For me the trick is keeping the fuel temp above the parra fin drop out temp. As mentioned in another post I will be adding a fuel tank heater pad or two. They are so cheap and crazy not to take the precaution especially when you see how much time can be lost getting going. I dropped the manufacturer of the fuel additiv a line and explained our difficulties, but still waiting on a response.
26th August 2017, 09:20 PM
#789
26th August 2017, 09:22 PM
#790
Zero snow on the whole tray canopy warmish area maybe?
