Page 789 of 1056 FirstFirst ... 289689739779787788789790791799839889 ... LastLast
Results 7,881 to 7,890 of 10559
  1. #7881
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Is that so you can put the windows up AFTER you've turned the key off ?
    Yes.... But this doesn't work on the drivers window as its not control by the relay.
    http://www.ebay.com.au/itm/GU-Nissan...-/122374891586
  4. #7883
    Jun 2015
    Heyfield Vic
    35 Post(s)
    That's 1 thing that pisses me off with the Patrol , turn key off& notice a window down so have to turn key back on etc , seems petty but it's a nuisance- I can take the keys out of the Commodore & close the door & still be able to just open the door & hit the window button .
  5. #7884
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Wonder why just that window isn't controlled through the relay ?
  6. #7885
    Yeah our Bommodore is the same. I reckon there one more thing that would piss me off about your Patrol too! Haha!
    Absolutely no idea as to why this is the case.
    I reckon I can by pass it via the window switch and then it has power all the time.
  7. #7886
    Jul 2013
    3 Post(s)
    Fitted a power window relay delay timer. Works well, but it doesn't work on the drivers window. Strange as to why. I pulled the relay out and the drivers window still works, but the other three don't. Hmm. I'm sure I can bypass the drivers window via the switch itself...
    Talking of electric windows, I had a look at a DX ute with a 4.2 diesel motor and noticed there`s no window winder on the drivers side door, but there`s one on the passenger side door. Found out the bloke who owned it, put in a electric winder in hooked up to a toggle switch. Had to laugh.
  8. The Following 2 Users Say Thank You to Bush Ranger For This Useful Post:
    MB (25th August 2017), mudski (24th August 2017)
  9. #7887
    Took the Pootrol out this arvo to blow the cobwebs out of it, I had a strange noise coming from underneath, I look and found I have a broken exhaust bracket, the one above the rear diff, and also the bracket that bolts to the transmission is near cracked right through. I finally ticked about 6 things off the "to do" list this week and just added two back on.
  10. The Following 4 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (27th August 2017), Bush Ranger (25th August 2017), Hodge (25th August 2017), MB (25th August 2017)
  11. #7888
    Jul 2013
    3 Post(s)
    ^^^ One step forward, two steps back.
  12. #7889
    Aaaand I've just added more on to the list.
    So I bought a new driver seat cushion yonks ago as mines stuffed. I finished work this arvo early enough so I thought I'd get the seat out of the Patrol and apart. Yep the cushion is rooted as I thought....
    ...but I found more. Hope my mig welding skills are up to scratch.
  13. The Following 4 Users Say Thank You to mudski For This Useful Post:
    GQtdauto (29th August 2017), katwoman (29th August 2017), my third 256 (3rd September 2017), Stropp (29th August 2017)
  14. #7890
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Ouch.... is that the floor pan? How much did the bloke who owned it before you weigh?
    And is the seat cushion reasonable $$$?
