6th August 2017, 08:11 AM
#7831
Missing in Action
PeeBee
I might just hold off on swapping out my hid globes to these based on what you found. I reckon my hid' are great, just as illegal in vic as LEDs, - what did you change from , halogens? I have the globes sitting there to swap, but still not convinced. I run led light bars for high beam and they are great, running them at 28v, so just about nameplate output.
Upgraded from halogen. I like the color output from the LED's, nice & bright especially when coming down from high beam, halogens seemed a bit dull after the brightness of the LED driving lights. Only bought cheap ones of eBay, a better brand might put out a bit more light on high.
Sent from my campfire using smoke signals.
The Following 2 Users Say Thank You to VK2FMIA For This Useful Post:
GQtdauto (6th August 2017), PeeBee (6th August 2017)
6th August 2017 08:11 AM
6th August 2017, 11:08 PM
#7832
finished the install of my 4WD Systems drawers, very happy. Did the door opening mod so the fridge doesn't hit it, next is to make a removable mesh "cage and shelf" to go around and over the fridge. Did the templates today.
GU8 2012 Simpson anniversary model, 3" redback exhaust, 2nd primary filter (original secondary), provent 200, Scangauge, engine watchdog, remote uhf dash plug, DRL's, pillarpod with pyro and boost, Titan drawer system, tail light upgrade, more to come
![Icon Driving](images/smilies/icon_driving.gif)
The Following 2 Users Say Thank You to shantillylais For This Useful Post:
GQtdauto (6th August 2017), MB (12th August 2017)
6th August 2017, 11:16 PM
#7833
mudski
Cheap OEM copies. eBay specials. I'll see if I can get the busted hub swapped under warranty. But my auto hubs are a bit worse for wear, hence me buying these, so I might have to fork out the coin for genuine hubs.
I think I still have a set of locking hubs off a GQ in a brothel box in the shed .
7th August 2017, 10:41 AM
#7834
shantillylais
I was lazy and bought this and just made it fit...
http://www.ebay.com.au/itm/Steel-Fri...item212b19c71d
shantillylais (7th August 2017)
7th August 2017, 10:49 AM
#7835
Finally pulled the manual clutch pedal and brake pedals out, in preparation for swapping over to an auto. Poor things needing some attention, spent the last month working on other cars instead. oo also sent the converter off to be rebuilt and tuffened up
The Following User Says Thank You to johno90 For This Useful Post:
7th August 2017, 10:50 AM
#7836
@MudRunnerTD again. Busted... I knew that sound wasn't normal mate. I should have gotten you to go for a run down a hill in my car at Licola. The noise was horrible and was felt through the entire car.
The Following 3 Users Say Thank You to mudski For This Useful Post:
Hodge (7th August 2017), MB (12th August 2017), MudRunnerTD (7th August 2017)
7th August 2017, 10:13 PM
#7837
thanks mudski, I had seen similar, but I wanted more a usable shelf on top. It will be from the backseat to the door (950 long, and from the fixed side to the 3rd row grab handle), so mine will be more like a half of the Black Widow system, and with 5 screws install/remove when not using the fridge. If I could justify the cost, I would have just bought one tho'. cheers Lana
9th August 2017, 06:00 PM
#7838
Spent a few hours packing it with camping outfit ! Going high country on Friday . First time fully packed with the new draws and I'm liking it. Neat tidy and tucked away .
It's ready just gotta add beer and meat at Mansfield and we're off !
Pumped !
The Following User Says Thank You to Hodge For This Useful Post:
9th August 2017, 06:03 PM
#7839
Hodge
Pumped !
Enjoy Hodge, yeah drawers are awsome, you'll love em
The Following User Says Thank You to Rossco For This Useful Post:
11th August 2017, 08:19 PM
#7840
PeeBee
I will stick up some photos when I have it installed. Currently tacked up and waiting for the welders touch to finish. MB posted up some shots of how Millweld rework the safari hole in the guard. I am undecided yet how this coverplate will look, so need to think a bit more. The millweld setup is very neat for sure. When is your getting fitted Rossco?
Rushed home from Stanhope today and fitted the snorkle. Very happy with it and looks great.DSC01755.JPGDSC01756.JPG
Shown with ramhead and also the Donaldson 305mm pre cleaner fitted
The Following 6 Users Say Thank You to PeeBee For This Useful Post:
Clunk (11th August 2017), GQtdauto (11th August 2017), MB (12th August 2017), Rossco (12th August 2017), Touses (13th August 2017), VK2FMIA (13th August 2017)
