Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: eBay intercoolers
    588 Post(s)
    eBay intercoolers
    Bit of a general question re Chinese special EBay intercoolers.
    Looks like my front mount IC has finally carked it and I'm not welding it back up again.
    I haven't measured anything properly yet but maybe the usual 600x300 size with 3" or 2.5" inlet outlets.
    Just checking what eBay sellers or eBay intercoolers members have bought and their thoughts on quality, etc.
    Don't want cheap and nasty just a good medium range...
    Looking at spending $200-400 ish then just get a universal pipe kit.
    Has anyone used those Aeroflows?
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I bought this one a few years back. It's 450 x 300 x 76 with 2.5" in/out. Bar & plate.
    Paid $159 for it with postage. Done about 10k kms and no issues.
    IMO, it appears to be well made. The welds look pretty good.
    The end tanks are cast and are pretty thick so they soak a lot of heat.
    John
  3. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    AB (28th July 2017), MudRunnerTD (29th July 2017)
    588 Post(s)
    Cheers mate good to hear.
    Anyone else?
    Those Aeroflow's are scattered all over eBay.
    North brissy
    Aeroflow are fine. From a little more extensive testing we have been doing with the borg warner you could go to a 63mm (2.5") wide core. Even slightly smaller say 500x200. Anything around the $150-200 mark will be more than good enough quality wise. Then just run 2.5" hot side plumbing and 3" cold side plumbing.
  6. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    AB (30th July 2017), MudRunnerTD (30th July 2017)
    588 Post(s)
    Thanks matty, yeah this custom wrx intercooler is ridiculously thick so a 2.5" wide core would be a lot easier.
    North brissy
    http://m.ebay.com.au/itm/New-Front-M...%257Ciid%253A7
    This is what oldmav ia using in his latest creation with no performance losses running just over 200rwkw and 700+nm of torque. He is also got his 0-100km/h time down to 7.6sec
  9. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    AB (30th July 2017), MudRunnerTD (30th July 2017), PeeBee (30th July 2017)
  10. #7
    Morayfield, QLD
    13 Post(s)
    I'm pleased to see it's confirmed that you don't really need to spend $2k+ on an intercooler..
    John
  11. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    AB (30th July 2017), growler2058 (31st July 2017)
  12. #8
    North brissy
    Yes you can. It requires a little more effort but still not a lot and the outcomes is as good or better. The cooler setup old mav uses on the setup I mentioned set him back about $300
  13. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    jff45 (30th July 2017), PeeBee (30th July 2017)
  14. #9
    331 Post(s)
    This looks good too.......
    http://m.ebay.com.au/itm/All-New-POL...%257Ciid%253A5
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (30th July 2017)
  16. #10
    197 Post(s)
    Would be interesting to see how they flow tune on the inside, but this statement is a bit of a concern to me -
    Please note you will need to machine 2x extra ports as it will not line up with the standard pattern.
  17. The Following User Says Thank You to PeeBee For This Useful Post:
