29th July 2017, 06:07 PM
#7801
Fitted the fuel flowmeters and computer today, no correlation between the programming instructions and whats on the actual screen, completly different so a call to the vendor required to get it set up.
Removed the original Safari Snorkle and cut the hole for the new SS 4" unit. Its not a pretty outcome as the original hole cut by ARB is huge for reasons unknown, and the 3 off mounting holes, they are at least 22mm dia for m10 bolts - I understand they don't have time for fancy fitting up, but this is disgraceful to be honest. In fairness I guess you would never see them, but I can see the damn things now! I have fitted black rubber grommets and its acceptable, but the bigger hole under the 4" bend is going to be a panel beaters job I reckon. Quite a cavity below the elbow, makes me wonder how the likes of Patrol a part and Millweld sort this out.
29th July 2017 06:07 PM
29th July 2017, 06:08 PM
#7802
bigguwesty
I take it this is with two tanks? I have 220L on board already across 2 tanks, but lifting the body for the additional 30L wouldn't be justified I reckon for me.
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
BigRAWesty (29th July 2017), Winnie (29th July 2017)
29th July 2017, 06:18 PM
#7803
PeeBee
Uea thats 2 tanks.
160 main and 90 sub for body lift.
140 main and 70 sub for standard..
I only have 150 atm in factory tanks (modded rear main to fit 110).
What tanks are you running to achieve 220L?
29th July 2017, 06:25 PM
#7804
bigguwesty
Uea thats 2 tanks.
Both Brown Davis units, 147 rear and 75 Belly. Good tanks, were expensive at the time I bought them as the price has hardly gone up from 1997 till now, but saying that, they have been trouble free until I fitted the 6.5 and then had issues with the draw from the belly tank - its fitted with a 1/4" outlet hoes whilst the main is 5/16", and the motor starves, so have converted it to transfer fuel back to the main tank, problem fixed.
29th July 2017, 07:04 PM
#7805
PeeBee
Yea they are made to keep the factory transfer setup..
Are the alloy plated sheet or just mild steel do you know?
29th July 2017, 07:11 PM
#7806
bigguwesty
Even back then, BD had moved to the plated material. I did punch a hole in the rear tank but simply emptied it at home and patched it. The set-up he sold and probably still sells is the multi port selector valve. I have only had one die in all that time, so a very reliable setup.
29th July 2017, 08:54 PM
#7807
After repeatedly bending up my trailer socket on the old bracket I decided to buy a new one and put it in the bumper.
2007 GU ST-S 4.8 Patrol.
40mm heavy duty springs, Dual batteries,
140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
The Following 2 Users Say Thank You to Skitzyrex For This Useful Post:
BigRAWesty (30th July 2017), Clunk (29th July 2017)
29th July 2017, 09:28 PM
#7808
Fitted up a flush mount RJ45 socket for my Icom UHF and also a RAM IPad mount using the seat rail bolt.
30th July 2017, 04:31 PM
#7809
Got my spare set of Koni's reco'd and swapped them out in the rear - fronts next weekend, too stuffed plus pressure to 'get out from under that bloody car' from 'you know who - the cushion queen'.
The Following 5 Users Say Thank You to PeeBee For This Useful Post:
GQtdauto (30th July 2017), TPC (30th July 2017), VK2FMIA (5th August 2017), Winnie (30th July 2017), Yeti's Beast (31st July 2017)
30th July 2017, 06:57 PM
#7810
Skitzyrex
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/07/330.jpg)
Mine has been smashed after the trip and i hate the flat plug.
So will be doing the same and mounting a round plug socket on the bumper..
Skitzyrex (30th July 2017)
