Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Nope, two gas tanks are inside. One on the side near the windows and the other is a scuba tank(three scuba tanks connected as one), so it compromises the cabin space.
230L petrol capacity under the chassis is new news for me. I didn't think that's possible, but then again it's a matter of getting a slightly bigger main tank I reckon. Somehow I suspect it is a fair bit more expensive than LPG tanks and most folks don't push under chassis tank capacity to 230L 'cos the it's heaps cheaper to carry jerry cans?!!
Cheetah Outreach
Actually, I can design and build a steel tank myself for more petrol capacity, rather than paying a fortune to get it done, thought I'm not too sure about the legality of it.
Cheetah Outreach
Cheetah Outreach
Cheetah Outreach
Ok, cool. Anything above that will be custom made ones then. The LRA auxiliary tank is a 68 litres. I guess it's a tough ask
to make a tank any bigger than that to fit next to the drive shaft on the right hand side.
Left side's got no room 'cos of the muffler. 150+70 =220, should give around 800kms on tough terrain or 1000kms on hihgways.
Better option for the outback. I reckon if I setup the tanks to switch between LPG & petrol depending on where I go, to fit the tanks whenever necessary isn't all that impossible. Remvoe the LPG tank, plug it and then fit the petrol tank. It's doable.
I think I have an idea to customize el cheapo large tank to fit to the back of the Patrol. Bit of panel beating & welding.
Cheetah Outreach
Here is a one if you wanna make an offer and get it delivered.
http://www.ebay.com.au/itm/1988-Niss...AAAOSwjVVV1nfM
Cheetah Outreach
