Yeah still not the one I remember, cheers anyway craig. Had a bit of a dig might have more of a look later. . .
Anyways finished painting chassis with brush, looks pretty smick. .
Found a new use for the top of the front coil towers. . .
After taking the plates off they were full of enough dirt for some nice pot plants ! . .
A bit better cleaned out, should save a bit of weight. Put in some 15mm coil spacers all round too, so with the reduced body lift should be similar to what it was.
Cleaned the TI sound deadening in the engine bay & put it in.
AND put the new cab on with new body mounts & bolts. . . Excitement ☺☺☺
AB (9th July 2017), Avo (10th July 2017), Bacho86 (12th July 2017), BrazilianY60 (27th April 2021), Chappy (18th July 2017), Family4x4 (8th May 2020), gaddy (10th July 2017), GQtdauto (9th July 2017), growler2058 (10th July 2017), gubigfish (9th July 2017), Maxhead (9th July 2017), MB (10th July 2017), MudRunnerTD (10th July 2017), mudski (9th July 2017), PeeBee (9th July 2017), Softy (9th July 2017), Stropp (10th July 2017), TPC (9th July 2017), Winnie (9th July 2017)
Looking good Rossco .
Rossco (9th July 2017)
The body is back on so you're officially putting the car back together now! Home stretch baby!
I've never seen that sound deadening in the engine bay before, did you pull that off your new cab? Every little bit helps.
I am very impressed. Watching this come together is voyeuristic
Patrol porn....
growler2058 (10th July 2017), Rossco (9th July 2017)
Yep ! ! ☺ Yeah was quite a milestone today.
Yeah was in the engine bay of the new cab, was a ti so they have it. Gave it a light scrub and came up pretty nice. Yeah interesting to see how different it is, hopefully it's quieter! !
Was going to reuse the stuff on the cab side out of the silver one but is a little ratty. . Might give patrolapart a call tomoz see what they've got, if not do a bit of a patch job.
Only just getting back into the forum now we've finished work for 6weeks or so , good read @Rossco - great work man 👍🏼 Are you coming to Licola & will this be ready if you are ?
