Yeah they do the same kits I had in the post. Same price.
Std TD42T GU III turbo with bits n pces that came off cross over pipe etc.
turbo was ok I just updated it.
+ a already modified zd air box.
make me an offer I cant refuse and its yours.
location wyee nsw.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
Thanks Robo but want to stick new gear on it, cheers though.
That Kit you linked is a DTS Garrett Kit with one of HPDs cooler kits. The last DTS kit I sourced for someone came in just under $3200. This included a full 2.5" exhaust system, boost and pyro gauges. The DTS kits come with reasonable instructions and can easily be done in a weekend. If you insert the drain in the fashion they say to you will need a nice spike and a thread tap.
I would price a DTS kit then add a cooler to it. You can do a cooler kit with a core and universal pipe kit off ebay for less than 500. Lot of ways to save money.
Must be different turbo, 3" dump pipe not 2.5". But no exhaust included. No gauges but that doesn't worry me too much I would like to go the redarc with boost and pyro together.
I would be keen on seeing the install instructions if anyone has a set.
Pretty keen on getting a price but without gauges if you still do that sort of thing.
