Results 1 to 5 of 5
Thread: Cluster fail / odometer overclocking
    May 2017
    Hi all,
    I hope you are well. I am based in Nairobi, Kenya, recently bought a second hand Nissan Patrol 2004 TB45 (4.5 Liter Petrol). The odometer is overclocking, for example, 5km for every 1km travelled. I took it to my local mechanic who have diagnosed a cluster fail and quoted USD 2000 for a new cluster. Though from my google searches I can see this is quite a common problem / defect for Nissan Patrols with lots of different options out there to fix, from earthing, to correcting voltage sparks / fluctuations. I am not a mechanic or mechanically savvy enough to do these.
    Basically wanted to check if anyone has had a similar problem and if there is a temporary or permanent fix to the issue? My concern is spending money on a new cluster and then the problem still continuing.
    Thank you!
    Mowgli
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate
  4. The Following User Says Thank You to Dhuck For This Useful Post:
    mowgli (30th May 2017)
    May 2017
    Thank you, how are things down under?
    Mar 2017
    Hi mate, sorry to hear about your situation, found it interesting..
    Hope that you get it fixed asap. less the coin..!
    cheers
  7. The Following 2 Users Say Thank You to in4m3 For This Useful Post:
    JackCollo (4th June 2017), mowgli (30th May 2017)
  8. #5
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day and welcome to the forum mate.
  9. The Following User Says Thank You to 4bye4 For This Useful Post:
    mowgli (31st May 2017)
