14th May 2017, 05:09 PM
Hi or low mount turbo?
G'day all.
Hoping for some advice on what the advantages/disadvantages are
Of a high versus low mount turbos on a td 42
14th May 2017 05:09 PM
14th May 2017, 05:18 PM
I went for a high mount setup on my GQ partly because it was easier to work on, however if you want a top mount intercooler you might have issues running a high mount
The Following User Says Thank You to gubigfish For This Useful Post:
Deano2506 (14th May 2017)
14th May 2017, 08:52 PM
Thanks for that.
Makes sense too.
I plan on running a intercooler after i get the turbo done,so that's very helpfull info
14th May 2017, 10:15 PM
Engine bay temps would be lower using a low mount setup. Further from the aux battery too if you have one. Easier intake plumbing maybe with a high mount though.
15th May 2017, 07:48 AM
Another good point.
I guess the turbo itself would run cooler with low mount too
15th May 2017, 08:33 AM
I think i read somewhere too about the flow dynamics. It was better with the low mount. But I'm not sure if it was about this or not. I run a low mount. If I was given the coice, low mount still. To me it just seems a better position and out of the way too... Doesn't look as good though...
Deano2506 (15th May 2017)
15th May 2017, 05:37 PM
Hmmm.flow dynamics...I'll look into that a bit more.
I'm not worried how it looks just what goes better.
Cheers for the info
15th May 2017, 05:51 PM
@nissannewby is probably the most qualified to talk about this
15th May 2017, 05:55 PM
gubigfish
Most definitely....
15th May 2017, 06:56 PM
gubigfish
Not sure about that
A well designed high mount can be just as good as a low mount. Low mount I would be using a dts item. They are nice heavy cast and are very open and direct compared to a standard manifold.
For high mount I would be using the latest item from radius fab recent testing by a well known shop has shown some nice gains over the standard nissan manifold.
I dont see to much difference in where the heat and everything is. Piping is very similar unless you do run a top mount cooler then a high mount might cause some dramas. Depending on turbo sometimes wastegate actuator placement can be fiddly on a high mount setup.
