14th May 2017, 11:21 AM
#701
14th May 2017 11:21 AM
14th May 2017, 11:29 AM
#702
MB
Some good news, just picked up Rossco's old alt and I'm 99.99% hopeful after measuring it will fit, bolt out, bolt in :-)
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/05/93.jpg)
Hole measurements spacings are identical
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/05/94.jpg)
The only difference looks like the GQTD42 alt vac pump protudes a further 15mm max.
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/05/95.jpg)
Thanks for the 170a ebay link Phil, I'm biting the bullet and maxing the M/C now ;-)
Excellent.
14th May 2017, 11:56 AM
#703
Hmmmmmmm... Says the item has ended 'unsold' and the seller only has 2 x second hand cars in their 'other' items :-( Maybe a 170a GQTD42 alt was too good to be true! Sent seller a message, fingers crossed for a response some day.
14th May 2017, 12:30 PM
#704
Have you tried patrolapart @MB thats where I got my replacement alternator for me ute, granted I'm only running a 4.2Ti
The Following User Says Thank You to gubigfish For This Useful Post:
14th May 2017, 12:33 PM
#705
Sure have mate :-) It was 'Shorty' on the counter that said the 125a had ceased production and highest available now was something like 110a I think. My truck needs double that in theory!
14th May 2017, 12:40 PM
#706
Just found another link on the Delco Remy 38SI 'new release' (a Borg Warner Company) has several videos within the link, super impressive alternators! http://delco.remy.bitwisesolutions.c...el-Family/38SI
14th May 2017, 02:05 PM
#707
MB
Mark, the item has ended because the auction period expired. He has relisted the alternator, have another look.
14th May 2017, 02:29 PM
#708
Ok great, so it is, thanks Phil! Quite brief 'Item description' says 'guaranteed' so I guess if it doesn't pull a true 170a should be returnable even though the advert says 'no returns'? I'm not too savy on electrics mate, do you reckon it's even possible to squeeze 170a out of an alt that size mate?
14th May 2017, 03:01 PM
#709
MB
You need to send the guy a question on the 'duty cycle rating' as this is important if you are after a power source to satisfy your demand. Your demand in all likelihood is going to typically be topping up of the battery after starting on a daily basis. Any alternator will handle that. Your 36a draw for the fans is probably getting up close to what the manufacturer would be happy with on a constant basis for a 90a unit also.
Your focus is on the extreme end of the scale where you have sustained draw at high current. So, I have no doubt this alternator could supply 170a but the question is for how long? If you are sitting on the side of a hill and have to winch for 45 minutes with breaks in between, you might find this is adequate. It will get hot, and its performance will taper off to a degree. The next thing you then need to consider is the battery you are using and if it can take the sustained draw down and then boost charge over an extended period - it will also get hot. Will your battery isolation system handle 170a also, as this could be another issue. I have for this reason got the 200a unit hooked up directly to the 1200cca/200A/h battery without intermediate control. The smaller 110a unit goes int the CTEK controllers and the batteries get up to an 80a boost charge and then a 20a staged charge.
The advert is pitched at high amp users such as in comp trucks, but maybe see if you can find out what the comp truck guys do, especially the winch challenges - this is perhaps a more relevant starting point, especially with the outlay, and you want to be happy with the result. I can't find where I bought my 200a unit unfortunately but it was from the USA.
Sorry, as usual a bit long winded, but you need to consider the system as well. Is there a comp truck guy within the forum who can advise on what they have used to set up for this duty?
14th May 2017, 03:55 PM
#710
The 747
Comp truck guys all run 24V systems, so theoretically half the current draw but realistically are winching for only about 30 second at a time. I couldn't see you winching for more than a few minutes at a time either Mark and with short breaks in between as well. Can't think of a time I have winched for more than 10 minutes at a time, with breaks to re run the winch rope.
Their lifespan on their batteries is quite short though and might have to replace them every few race meets.
Keep in mind these guys are running at least 2x 6hp motors at 24V, electric thermo fans etc... as well.
The Following 2 Users Say Thank You to Winnie For This Useful Post:
MB (14th May 2017), PeeBee (14th May 2017)
