Right oh time for paint
Macca
GQtdauto (3rd May 2017)
Coffee time
Macca
The wagon doesn't have that advantage..
John
Does Clearview supply the correct brackets to mount to the GU if you buy their expensive mirrors or do you have to get that fabricated yourself?
@gubigfish
My guess is they would replace the OEM mirror simply swapping one for the other and the wiring plug will match what's in the car too.
For the money that's what you would expect.
Macca
Yes , Clearview are model specific and are just a simple bolt in and plug in job .
Checked my distance for the mirror and I'm under the 250 mm , GQ sticks out about in the rear side above the back wheel and if you take the flares as the widest part of the car I'm under easy .
