12th April 2017, 09:30 PM
#3631
Patrol Goddess
After the wheel alignment guy said my front wheels are about to fall off I bought bearings. ![](https://s3.amazonaws.com/tapatalk-emoji/emoji16.png)
KATROL- The 2nd
GU TD42TGi
Silent member 1208
The Following User Says Thank You to katwoman For This Useful Post:
GQtdauto (12th April 2017)
12th April 2017 09:30 PM
13th April 2017, 12:41 PM
#3632
Enjoying the trips
http://www.allfourx4.com.au/epages/s...on=ViewProduct
So fed up with the Warn winch I have now, every time I want to use it, it fails! That's 2 Warns kark it in 12 years, for what they charge I was hoping for a better service life.
Snigging firewood logs Tuesday and it died again aarrrgggh.
The brushes get stuck in the slides they are located in and as the motor is not solidly attached to the winch it moves around and pushes the little buggers away from the commutator. This is the 6th time I've tried to fix this.
So a 12000lb fits, up from 9500lb and hopefully ticks the boxes. About half the price of a Warn too.
Macca
![](image.php?s=eb97b656f8fc9e180b78045fc5b053a1&u=962&type=sigpic&dateline=1361692028)
13th April 2017, 12:53 PM
#3633
macca
Should'nt have any trouble with that iv'e got an iron man and have snigged logs with it lol not as flash as your new one
The Following User Says Thank You to Sir Roofy For This Useful Post:
13th April 2017, 01:03 PM
#3634
Hodge
Probably better then the small brackets they sent me with the bar...
You can buy a bracket to suit the way you're mounting your bar.
I brought a pair so I can fit a 42" single row along the side.
I'll try and find the link again, or just type in bullbar brackets
Sunyee and Vic Off Road sell them for about $20 a pair
just need to find the correct size. Protect your bar with a
few wraps of electrical tap when fitting them.
http://www.ebay.com.au/itm/Pair-2-Bu...cAAOSwhOVXdyp2
13th April 2017, 01:16 PM
#3635
The 747
macca
I had one of those and it was a great winch. It did get full of water though.
13th April 2017, 01:28 PM
#3636
macca
I have the email address of Steve from Warn USA if you'd like to have a chat.
I speak to him on a regular basis
13th April 2017, 01:31 PM
#3637
Enjoying the trips
Winnie
Looked at reviews Winnie and water was noted by one and heaps of others said they had no problems, the question is if the actually serviced them and had a look inside.
That was the trouble with the Warns, water did get in but not all of it drains out of the drain hole. On a warm day it condensates all over the insides causing corrosion.
Macca
13th April 2017, 01:37 PM
#3638
you could pressurise it using an airhorn motor and a needle valve.
You'd need to drill and tap a hole for the air fitting
13th April 2017, 02:30 PM
#3639
threedogs
Thanks John. That makes life a whole lot easier .... I was gonna drill a hole from each side , in line with the threads of the bar and then push the bolts through that way ... But those brackets you linked would be perfect !
threedogs (13th April 2017)
13th April 2017, 04:50 PM
#3640
You spend mega bucks on a winch and have to fit something to keep the water out and the thing plays up , $199 from Aldi and still going strong after 4-5 years and got me out of trouble heaps of times .
Also used it to straighten the shed and pulled a few stumps out .
The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
Hodge (13th April 2017), mudnut (13th April 2017)
