Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 73
Thread: DavesStuff Tuturial Video's posted on Youtube
  1. #21
    477 Post(s)
    May I also recommend these little ripper cast iron additions to your tucker arsenal in Phil's oven mate! The iron crock pots hold a single serve Osso Buco slow cook stew cut and the mini frypans can do leg ham & egg cupcakes with tobasco/parmesan topping for breaky, delicious:-)!!
  2. The Following 2 Users Say Thank You to MB For This Useful Post:
    Clunk (7th April 2017), PeeBee (8th April 2017)
  3. #22
    197 Post(s)
    These look great, excellent ideas. Regards the temp probes I initially discounted their use as I used IR probe, however I still need to open the oven door to do the reading. I thought about putting a 6mm hole in the oven box so a probe could be slid in to contact the pot or just measure the oven temp, but was unsure on how much smoke I would lose. Might be time to start playing around again and get a probe integrated. My hesitation with the greasy probe scenario is purely if the glass breaks and shatters, and you don't pick that up - could end up with glass in pizza - not a good thing.
  4. #23
    197 Post(s)
    For sure, top idea charcoal for that extra heat mate, will try that definitely! When I first tested mine with elcheapo heatbeads at home I ended up stacking a small piece of redgum sleeper on top of the top beads. Really did seem to force the beads heat downwards and lasted many hours for a ripping pork crackle top :-)
    How do you get the charcoal 'started'? Are heat bead lighter blocks sufficient? Who sell Charcoal as opposed to heat beads - can't say I have seen it domestically?
  5. #24
    I have a heap of those cast enamel pots from Aldi great size for a single serve Garlic prawns
    Think I only paid $6 each
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #25
    I can get charcoal from local chicken place @ $30 a bag.
    A mob in Richmond sells it buy the bag, I use it to blacksmith stuff
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #26
    197 Post(s)
    How do you get it started? Does it need a lot of forced air as such or does it burn 'in ambient conditions'?
  10. #27
    fire lighters get it started, and just ambient conditions do the job.
    Back in the UK, we pretty much only had charcoal for bbqs, heat beads weren't common and gas was way to expensive for the common folk. It was quite an eye opener here to see a gas bbq cheaper than a kettle bbq when I first came over here.
    This is an old friend of mines business, extremely passionate about what he does....... http://www.theoxfordcharcoalcompany.co.uk/ , also found on facebook
  11. #28
    197 Post(s)
    There you go, learnt something today! I will hunt some down and give it a go.
  12. #29
    Blacksmith coke is way too expensive and very hard to source
  13. #30
    Oh I meant to say, you can get charcoal from Bunnings, no idea what it's like though
  14. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    PeeBee (8th April 2017), threedogs (8th April 2017)
