4th April 2017, 02:23 PM
Did you do an earth connection with new head unit? I remember mine was real crap until I added one....
4th April 2017 02:23 PM
4th April 2017, 02:30 PM
Just wondering if you have a link to this whip antenna?
Bacho86
I thought the same thing.
The original factory cassette thing used the aerial as the ground.
These new units need a separate ground .
4th April 2017, 03:06 PM
mudski
I did notice it changed with the revs. Yeah i remember those suppressors too. But they were fitted to the ignition coil from memory...
Used to fit them to both. Especially on old minis. They never worried about suppression because they never came out with radios.
4th April 2017, 07:40 PM
Hodge
Believe it or not Mark. Mine is identical! Exact same symptoms.
It done it with factory aerial .
Then i completely cut it out and disconnected it and installed a Gme whip antenna like yours and issue is still present.
However mine only does it when motor is running. Motor off brings perfect radio reception.
But i never listen to radio anyway so i just ignored it.
Edit: mine is a pioneer head unit.
That clearly indicates noise interference from the ignition system.
4th April 2017, 08:18 PM
threedogs
Just because the batteries arent old doesnt mean they are not the problem.
Id be fitting an inline noise suppressor.
OOI I still use the OE antenna and have a "chit" eonon head unit and have no problems
whats so ever
Had a think I reckon you may have a "burnt" wire somewhere
So whats a "burnt" wire? I know my batteries arent causing this. This issue has been about since Ivé had the car. With different batteries...
Mike02Ti
It does sound like you have a ground loop of some sort. Have you added or changed the routing of any wiring ?
No routing for the stereo has been changed.
Bacho86
The body of the unit earths itself( well I assume it does) when I screw in the metal mounting brackets....
Throbbinhood
https://www.gme.net.au/catalogue/ant...one/aem2w.aspx
dom14
It does seem so...
I drove it today, for the first half hour the radio was crap, by the time I was heading home the reception was near perfect.
4th April 2017, 09:03 PM
#17
Routing for the radio doesnt need to change to introduce a ground loop. Any change in any wiring can potentially introduce it.
Another thing you could check alternator wiring. Have also heard of ignition coils and leads causing issues (from memory you have a diesel though so scratch that), fuel pumps etc.
Is there any power wiring in contact or running close to either the speaker wires/ amplifiers if you have them fitted or the head unit power source
Chasing ground loops suck. I chased mine for about 4 days before i found a cable running to the rear of the car in close proximity to the amp causing it. Didnt know it was there as it was like that when i got it.
Oh one more thing could be the preouts on the rear of the unit have a small amount of voltage in. If they are touching metal beind the dash that could also possibly cause it
The Following 2 Users Say Thank You to Mike02Ti For This Useful Post:
dom14 (5th April 2017), mudski (4th April 2017)
5th April 2017, 03:08 AM
#18
Mike02Ti
My bad...of course no point talking about interference from ignition on diesel engines.
5th April 2017, 09:26 AM
#19
Try a small portable radio. Tune it off station and turn volume up. Wave it over the vehicle and engine to locate the source.
The Following User Says Thank You to Turtle_au For This Useful Post:
5th April 2017, 10:13 AM
#20
Turtle_au
does that work sorta like a tracking collar??? @mudski maybe run another earth and see if that
improves it or not, even run it to one of your batteries
