Warwick89 (21st March 2017)
Well after a week of running around the issue has popped its little head up again. Had my mate from carline put his scan tool on and no errors and everything seems to be ok ie rail pressure at 116000kpa on accelerating air flow I think was around 53lit/min on idle so back to the drawing board on this one. Only thing I didn't check was boost pressure. Does anybody know what sort of air flow should be reading on idle
Cheer all.
Have you serviced the MAF sensor.
you could hook a temporary boost gauge up to see whats going on
using a patrol boost sensor adaptor
http://www.ebay.com.au/itm/Quick-Fit...8AAOSwsW9YwbzA
Are there any inline cage filters that can be inspected ??,
Ran a tank dry recently,??
I always leave 10-15 ltrs in my sub tank
I usually do the same by filling up aroun 1/4 tank but did a trip a few weeks ago and got down a little to low gor me also last rank of fuel was Costco have you herd any bad reports about their fuel at all and no I can't locate any accessible filters. Appreciate the help it's doing my head in.
