Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Generally the suburb is pretty good which is disappointing
in4m3 (30th May 2017)
some of those baby seats are pricey i feel for you.
Cheetah Outreach
Yarra valley it was. I'm sure it would be ok but don't want the little one to end up with a shard of glass in her clacker. Can never get rid of all of it unfortunately
being Safety glass i assume it shattered? you should be able to get it all using a vacuum. it will al be sitting on the surface as no-one or nothing has embedded it in by sitting in there.
Side note.
I would not be surprised if you have dropped a Pad. do you have a peddle back? Nissan are renowned for dropping pads. when it happens your foot goes to the floor. you pump it a few times and get a peddle back then your brake piston is doing the stopping.
Sounds like you need a front end rebuild anyway.
If your car is Full Comp Insured then your insurance will cover all the glass and lost items and probably the new car seat too to be honest. Give them a call, they will send our O'Briens Glass straight away.
nah that glass gets everywhere, real pita. i've got countless cuts from that stuff even through leather gloves. tiny shards get into everything i got a set of clothes i just threw out cos of the glass in it. clean up after a shattered windscreen.
Cheetah Outreach
Cheetah Outreach
