Results 1 to 10 of 17
Thread: Wheel bearings? Auto hubs?
    Oct 2011
    melbourne
    So as per my previous post. Though stuffed wheel bearings. Finally went to have a look today. Jacked it up. Went to lock the auto hubs but wouldn't. Closer inspection showed the little plate with the arrow gone. When trying to lock just keeps spinning.
    Oct 2011
    melbourne
    Sorry. Forgot to add......help!?!?
    475 Post(s)
    And please :-) Only joking mate, would honestly help if I knew, sorry, hopefully someone will be along soon!
    Oct 2011
    melbourne
    Haha bit rude of me MB
  6. The Following User Says Thank You to beexy For This Useful Post:
    MB (18th March 2017)
    475 Post(s)
    Bump for Beexy please folks, can anyone kindly help a bloke in need?
    Aug 2010
    adelaide
    might have to replace them or tighten them
    here is a thread for this thanks to one of our great members
    http://www.nissanpatrol.com.au/forum...ing-Adjustment
    OH LEATHER IS NICE
    Oct 2011
    melbourne
    My third thanks for the link. The issue I'm having is i can't even lock the hubs now. The nut just keeps on spinning if that makes sense. Not sure if you can take the auto hub off of you can't lock it?
  10. #8
    Oct 2011
    melbourne
    Hopefully the photo went through
  11. #9
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by beexy View Post
    Is it my imagination or does it look like something's come off the edges of the auto hub assembly centre bolt?!!
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  12. #10
    38 Post(s)
    I guess, you can take it off, but not without causing crud to get into the bearing assembly and damage it in no time.
    Auto hub or manual hub assembly works as a bearing dust cap as well, afaict.
    If the auto hub is stuffed and not engaging at all, I guess you can leave it until you fix it, unless the auto hub on the other side is working improperly and engaging when not in 4wd mode.
    Either way, I think it's a good idea to take the auto hub out and examine the wheel bearings closely, as well as the caliper, pads, rotors, etc.
    Cheetah Outreach
