9th March 2017, 08:25 PM
#601
Where are the shots of the bullbar? I need to see what you have done with the oil coolers.
9th March 2017 08:25 PM
9th March 2017, 08:33 PM
#602
Before and after 'dyno' drive in/outs would be perfect for here! You'll have to trust my honesty:-) In regards the reverse snorkel pipe choice, reasons being for me was that this truck is mainly off highway at lower speeds. Past my 4.2TD's and current Mrs MB's GU's experienced dust/mist/mud blockages on TJM-Airtecs with tiny back drains, Safari snorkels were shitloads better. Second reason for the 6.5 beast is snow/sleet over winter in the HC. That ice builds up and blocks forward facing heads/drains in my opinion. Thirdly, as much as I shouldn't say this but I do know how to use a 'Hi-Lift' jack on my ute tray corners safely so a 'Ram-Head' would block my rack mount up top :-)
The Following 2 Users Say Thank You to MB For This Useful Post:
PeeBee (9th March 2017), rainsey (9th March 2017)
10th March 2017, 06:21 PM
#603
Administrator
MB
Very very happy to report that the 4" snorkel and airbox/new custom route all done by Mill @Millweld has worked wonders! Do need to reinstall the second battery now on the chassis as previously planned. Too early to give exact figures and oil coolers aren't hooked up as yet but I can say powers up a minimum 10% would like to say 20% but that's probably too much excitement from its newfound grumble free flowing sound! I do know that water temps truly appear to be more stable, 88-92D max on the flat highway stuff back. I pushed it to roughly 102D on the last final test hill home which depending on ambient temps unloaded would reach between 104-114D tops after last radiator mods. The most intriguing thing has been fuel consumption does appear to be down significantly!! Stay tuned, like Rainsey, works flat out and we all need the coin to keep going:-)
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/03/82.jpg)
Haven't even had a chance to see this in person but looks very sexy mate!!!
12th March 2017, 04:56 PM
#604
I'm putting this out there and apologies if it has already been covered,
Brunswick has sent me over a fix radiator fan flange to see if the viscous coupler is faulty. Immediate results astounding with at threats a 15 degree temp drop in all ranges.
Now struggling to keep the just around town temps over 78 degrees.
Spam have a dual electric fan set up that almost fits perfectly into the space behind the radiator and engine. Only 105mm in depth, with a static air flow of around 3,000 cfm.
I'm not a fan ( pardon the pun) of fixed fans. I can already see my fuel gauge drop before my eyes. Has any one ever played with a total electric solution or has advise based on experience with electric fans.
My thought is as follows:
1: no load on the engine hence no hit on fuel usage
2: can be controlled via a temp switch if need be and easily tinkered with.
3: if doing a creek crossing, can actually be turned off
4: at 1 in h20 static pressure, it sucks 45 amps of current ... ouch.
Any advise would be appreciated.
Kindest regards
Rainsey
Sent from my iPad using Tapatalk HD
12th March 2017, 05:10 PM
#605
Rotaredom
rainsey
5: Thermo fans still run after ignition is switched off, cooling the radiator down
I know nothing of Chev motors but my only advise would be if going thermo fans, is make sure you have a good shroud around them
rainsey (12th March 2017)
12th March 2017, 05:22 PM
#606
NissanGQ4.2
Yeah, No brainer there, I have an aluminum Fabricator that has done some work for me that can build one. The shroud, perse, probably only needs to be the interface between the fans and the radiator as the Spal unit I'm looking at has a complete twin fan assembly in a frame already.
Rainsey
The Following User Says Thank You to rainsey For This Useful Post:
NissanGQ4.2 (12th March 2017)
12th March 2017, 05:26 PM
#607
G'day Rainsey, I'm running 2 x Davies Craig 16" fans side by side that pull 2120 cfm each. My reasons were mainly for as you've suggested for easy shut off in creek crossings and heaps of pull still at lower rpm crawling speeds. I do believe though that a good mechanical fan system will outperform my setup on the highway. I do also need to add a second alternator though because each fan draws 19amps and are controlled through a 'Derale' twin thermo switch system roughly 10F degrees apart. So if I need to winch and both fans are on I'm stuffed at the moment. Other cooling mods underway should see the second fan almost not needed I'm hoping.
Gotta head to dinner now so can send some pics tomorrow if you need mate, Cheers!
12th March 2017, 05:30 PM
#608
Almost forgot, there is a USA mob doing a twin electric setup for the Duramax donk now and it's a massive 6,000cfm (3,000 x 2 I assume) The amp draw was frightening though, I'll try and find the link tomorrow for you too.
12th March 2017, 05:35 PM
#609
NissanGQ4.2
On the thurmo fan running after the engine is turned off, I would consider this superfluous as in my naive understanding we want to cool the block. With the engine off, no water is circulated hence we are probably waisting good battery capacity for no reason.
More than happy to be shown the errors of my thought pattern.
Kindest regards
Rainsey
12th March 2017, 05:41 PM
#610
MB
You have just hit on something that I never thought of, thank you .... winching. Having said that, most of my winching has been short periods, probably no more than half an hour and not in a situation where I could not stop. This does not mean this will change.
I am pondering on the idea of a hydraulic winch. I still want to do this as you can winch all day and only suck 2 or 3 amps. The reason I have not done it yet is that with the set up under the bonnet with the serpentine belt, stuffed if I can figure out how to put in an additional oil pump. Don't want to winch off my stearing pump.
Thanks for the jog of the synaps. Good point.
Kindest regards
Rainsey
