Yea that sounds about right usually only does it on first start up of the day or if it's been left awhile
Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Hmmmmmm is there like a stepper motor or something like that on rb30 motors?
Stepper motor in where?!!
I reckon you experience high idling revs for too long when engine's cold started. Ideally it should settle once the engines warmed up, but that can be some time in cold weathers. Replace the cold running thermostat asap though. No good can come out of it, as I've experienced with mine.
Choking method in EFI ones afaik is the ECU causing the injectors to spray extra fuel.
Cheetah Outreach
dom14 (4th March 2017)
All good, found out I've got a sticky cable or something if I push up with my foot on the accelerator and it idles nice.
