25th February 2017, 08:56 PM
#7321
Smart like tractor
Swung a spanner on the ute for the first time in what seems like years. Pulled one front shock off as it has a bent shaft, the other one has pitting and rust has started showing up, so I'll replace the shafts, change the shim stack start and doing my own shock tuning
Only basic tools required to strip them down
96 GQ coil/Cab
08 G6eT
![](image.php?s=fd76de977c851e7651e2fa401f864f87&u=1281&type=sigpic&dateline=1483248064)
The Following 4 Users Say Thank You to Ben-e-boy For This Useful Post:
Clunk (27th February 2017), mudski (25th February 2017), threedogs (26th February 2017), Touses (27th February 2017)
25th February 2017 08:56 PM
26th February 2017, 12:29 PM
#7322
Almost finished tinting. I left the front windows to show the comparison.
IMO and should be taken with a grain of salt.
The Following 5 Users Say Thank You to Parksy For This Useful Post:
Clunk (27th February 2017), gubigfish (26th February 2017), jack (3rd March 2017), Rossco (1st March 2017), threedogs (26th February 2017)
26th February 2017, 01:54 PM
#7323
Patrol Guru
growler2058
Dawes and needle fitted cheers @
mudski for the call
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/02/190.jpg)
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/02/191.jpg)
![](http://www.nissanpatrol.com.au/forums/images/imported/2017/02/192.jpg)
And nearly got this all fitted. Just gotta tighten it up in the morning
What's with the excess exhaust tube sticking out past the flange? Did they not weld those on?
26th February 2017, 03:03 PM
#7324
@Parksy how hard has it been to do it yourself? Was looking at attempting it myself
26th February 2017, 04:07 PM
#7325
SPAMINATOR
gubigfish
Yes mate its welded, thats similar to male/female fitting
![](image.php?s=fd76de977c851e7651e2fa401f864f87&u=2058&type=sigpic&dateline=1604048275)
#7326
SPAMINATOR
Mike02Ti
Highly unlikely I'd have the patience for that :0
26th February 2017, 04:24 PM
#7327
Hey growler are Hahn making exhaust lube these days ?
26th February 2017, 04:28 PM
#7328
It takes a little practice but isn't that bad. I think the hardest part is cutting the tint to the correct size. I watched a lot of YouTube videos to get the technique down pat first.
The Following User Says Thank You to Parksy For This Useful Post:
Mike02Ti (27th February 2017)
27th February 2017, 08:59 AM
#7329
Patrol Guru
growler2058
OK never seen it like that before, so I take it the other end of the flange is only half on the pipe to get it to seal.
27th February 2017, 09:04 AM
#7330
growler2058
Did you think of wrapping the dump pipe to keep radiant heat away from your firewall??
I see the other end has a slight flare so it all fits together, very well thought out,,,,lol
