25th February 2017, 09:41 PM
Temp gauge reading cold
Have a gq with the rb30 efi. Conversion, the temp reads really cold it sits just above the bottom line even doing 120 on the highway is this normal?
Also have hooked a aftermarket gauge and reads the same think it was just above 40
Reason: Forgot to add some stuff
25th February 2017 09:41 PM
26th February 2017, 07:38 AM
i had a similar problem, my thermostat seized open.
26th February 2017, 08:34 AM
Change thermostat first, with a factory one, should fix your problem.
26th February 2017, 01:53 PM
Cheers fellas I'll check it out, what should it read at?
26th February 2017, 02:21 PM
well mine being a td42 it reads on the original about 1/3 pretty much everywhere doing almost anything. as for actual temp for an rb30 i guess about 80 ish deg ( an rb30 guy should be able to give a more acc guide) it will depend on which thermostat though a 77 deg will run a bit cooler than the 82 deg.
26th February 2017, 05:41 PM
lars04
The temperature should be 80-85 fully warmed up.
Get a genuine factory one. I bought an after market one off ebay but for the same price you can get genuine one here
http://patrolapart.com.au/product/ni...stat-suit-rb30
It made a huge difference in mine. Engine's running lot happier now.
Low temperature and high revs is a bad combination for piston rings and walls.
28th February 2017, 09:26 PM
Thanks mate will order now! So that could explain the random hight revs it has
28th February 2017, 09:36 PM
#8
lars04
Running at too low temperature causing random high revs? I'm not sure about that.
28th February 2017, 09:53 PM
#9
Any idea what would be doing that? Doesn't always happen and only does it for a short time then drops to normal
1st March 2017, 05:22 AM
#10
is like choke kicking in? the efi should have a choke like running condition if the temp drops it could be bringing the revs up to warm the engine.
The Following User Says Thank You to garett For This Useful Post:
