11th February 2017, 09:26 PM
#11
Bigcol
your gear box should be the same, just the bell housing is different
you should get 4.11 or 3.9 gears for the diff - (speedo accurate with 4.11 - but better take off and off road with 3.9's just low top
- or is it the other way around - cannot remember now
Gearbox is totally different on td42 to rd28. Transfer cases are the same but diffent adapter housing
11th February 2017 09:26 PM
11th February 2017, 09:27 PM
#12
Gearbox would be swapped out as well
12th February 2017, 12:34 AM
#13
there you go, I was told they were the same
I didnt know.....................
12th February 2017, 12:36 AM
#14
Anyone have any input on the compression readings I posted earlier? Is the engine worth it or am I looking at a dud?
13th February 2017, 07:10 AM
#15
Hey mate, yeah bugger hoping it would have checked out pretty well with low Ks and sounds like it runs & starts beutiful. Is it worth doing a another test know sometimes they can be a bit temperamental?
13th February 2017, 08:45 AM
#16
Administrator
Hey mate, assuming the engine was hot when you did the test?
13th February 2017, 12:04 PM
#17
Yes. The engine was hot when the test was done - it had just been driven over to the shop. I'm having him go back today and get the valves and lifters adjusted today and then will retest the compression to see if it makes any difference.
13th February 2017, 12:18 PM
#18
180k is nothing in AUS speak some here have
motors with 500k on them and still going strong
13th February 2017, 12:33 PM
#19
I'm not worried about the Ks on it. I'm a bit more concerned about the low compression readings. When I bought my RD I had one cylinder with a very low reading and it wound up costing me a complete rebuild within the year. Just want to make sure I don't make the same mistake with this engine.
13th February 2017, 12:34 PM
#20
AB
Yes it was hot/warm. Wasn't it supposed to be?
