Results 1 to 10 of 18
Thread: How have you secured your slip off pod to your tray ,.
    May 2011
    mackay former alice boy
    How have you secured your slip off pod to your tray guys as I'm in the process of setting mine up and wondered what you guys did. Pic's would be the go to save on typing over to you .
    U have 4 choices in life :U can like it; lump it; love it or shove it, take your pick and stick to it !
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I don't have one but it really would depend on how frequently you were removing it. I've never taken notice 2 how our jack on / off canopies get installed just know the normal canopies are just bolted down with a square gal washer each side.
    I'll ask at work on Monday what they normally do
  3. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    dads tractor (30th January 2017)
    May 2011
    Thanks mate dont want to bolt through floor so was wondering about a system to under the tray . Keep in mind this will not be on nice concrete drive ways just as a added challenge aye .
    The ideal would be camlocks like on trucks but too big .
    Jul 2012
    North East Victoria
    4 Post(s)
    I just bolt both my work canopy and camper down through the tray - only takes a few minutes with a cordless impact driver to undo the bolts. I don't use captive or welded on nuts under the tray because I use my ute as a ute a regularly and think that the threads would either corrode or get full of gunk. I just use a flat and a spring washer. Never had any dramas. Incidentally when getting the wind down legs make sure to offset the "coupling" so as to increase stability and allow the doors to open when off the ute. I had my brother modify both of mine ( he can weld )Securing 011.JPGSecuring 002.jpgSecuring 004.jpgSecuring 005.jpg
    Remember that a high IQ doesn't make up for a lack of common sense.
    Learn from the mistakes of others - you won't live long enough to make them all yourself !
  6. The Following 2 Users Say Thank You to Old Wal For This Useful Post:
    dads tractor (28th January 2017), MB (31st January 2017)
    over centre catches similar to a rear wheel carrier but smaller would work.
    I think they have a rating stamped on them
    http://www.ebay.com.au/itm/Trailer-O...2tc4RGcUD7xqlw
  8. The Following 2 Users Say Thank You to threedogs For This Useful Post:
  9. #6
    May 2011
    What did u find out mate NissanGQ4-2
  10. #7
    Aug 2010
    17 Post(s)
    Quote Originally Posted by dads tractor View Post
    Normally bolt them mate, you could use catches but believe they aren't as strong as bolting them and with a pod loaded up with weight why risk it considering it would only take a few mins to bolt on / off.
    Any reason you don't want 2 bolt down???
  11. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    dads tractor (31st January 2017)
  12. #8
    Aug 2014
    Perth
    10 Post(s)
    I spoke with a Pod builder over here in WA and they have some sort of fast latch system but it costs extra otherwise they bolt them down.
  13. The Following User Says Thank You to gubigfish For This Useful Post:
  14. #9
    477 Post(s)
    They're the same ones I believe I got off your mate Scotty in Tullamarine thanks again TD :-) It's not for a slide on camper but the entire tray slide on wacky contraption 3/4 finished below:
    Added the 16mm lock pins into the design for peace of mind. Reckon the 'catches' would need to be much chunkier/rated if relying solely on them. Bolting down may well be the cheapest, easiest and probably toughest option for a slide on camper.
  15. The Following 2 Users Say Thank You to MB For This Useful Post:
    dads tractor (31st January 2017), threedogs (1st February 2017)
  16. #10
    May 2011
    OK thanks for everyone's input ; why dont I want to use bolts through the tray because when I unload at no cement to jack on camp with no one in sight it's a bit hard to secure the pod back on and move it to get bolts back in .
  17. The Following 2 Users Say Thank You to dads tractor For This Useful Post:
    MB (31st January 2017), NissanGQ4.2 (1st February 2017)
