Page 49 of 135 FirstFirst ... 3947484950515999 ... LastLast
Results 481 to 490 of 1342
Thread: All Things Chev
  1. #481
    May 2011
    7 Post(s)
    If you are talking about the black fitting, this can be made to any height and shape you need by a good sheetmetal worker - its a simple transition cone. I think BD have probably gone for a standard element, but this could be reduced in height to say the diameter of the inlet pipe to the manifold.
    Hey, Thanks for the feedback. Bottom line is that I just wanted to purchase one and keep the one I have as is so I can get the set up prepared without having much if any down time. Does anyone know where these inlets can be bought from?
    Rainsey
    196 Post(s)
    Quote Originally Posted by rainsey View Post
    Rainsey
    I am in touch with a guy in Tamworth who has a GQ Optimiser conversion, originally n/a, then he turbo'd it locally. He has a monster top mount intercooler setup. I can get the name of the guys who did his turbo install for you. His installation was a bit of coin from memory, but you might be able to buy just the adapter. Making a custom is as simple as defining a couple of dimensions, then leave it to the sheetie. Anyway I will PM you his details, really nice old guy, very helpful.
    rainsey (28th January 2017)
  5. #483
    May 2011
    7 Post(s)
    Thanks heaps for that. I have a guy that can probably build an alloy unit, more I think of it, this might be the way to go. In my naive thought pattern I just assumed they would be a stock item for the Chev diesel. If you do have the contact fo the Tamworth guy I would be appreciative.
    Kindest regards
    Rainsey
  6. #484
    196 Post(s)
    PM sent about 15 minutes ago.
  7. The Following User Says Thank You to PeeBee For This Useful Post:
  8. #485
    475 Post(s)
    Finally got the tray back on the hybrid beast. Sliders & new bar next weeks project. Hoping I can catch up to you @PBBIZ2 on the Caledonia mate :-)
    Thanks again @threedogs , Scotty's lock pins worked a treat mate :-) !
  9. The Following 4 Users Say Thank You to MB For This Useful Post:
    BigRAWesty (29th January 2017), Kimbo63 (4th February 2017), mudski (28th January 2017), Rossco (29th January 2017)
  10. #486
    Looks better now Mark.
    MB (29th January 2017)
  12. #487
    May 2011
    7 Post(s)
    Now that looks like a nice body conversion. Something I am wanting to do one day myself to enlarge the cab.
    Out of curiosity what is the lock pins holding in?
    Rainsey
    Sent from my iPad using Tapatalk HD
  13. The Following User Says Thank You to rainsey For This Useful Post:
  14. #488
    475 Post(s)
    Cheers Rainsey, bought it from WA already converted by Laingley, they do a nice job that mob! The lock pins secure the tray on as I'm in the process of making multiple use trays for work, home and play. Installed a rear on-air Firestone sus system last year so I can leg under each tray with dolley wheels and deflate for quick drive out tray swap overs in the shed.
  15. The Following User Says Thank You to MB For This Useful Post:
    rainsey (29th January 2017)
  16. #489
    196 Post(s)
    Looks good Mark. Certainly welcome. Looks like it will be 2 nights on Caledonia and 2 on the Mcallister on butcher country track as the fishing is probably going to be better on the bigger river
  17. The Following User Says Thank You to PeeBee For This Useful Post:
  18. #490
    May 2011
    7 Post(s)
    Ha,
    Thunderbird 2.
  19. The Following 2 Users Say Thank You to rainsey For This Useful Post:
    MB (29th January 2017), Ropes (30th January 2017)
