Might be better off using a decent steel like the F.Dick ones,
http://www.ebay.com.au/itm/Vintage-F...cAAOSwJ7RYYHbu
gubigfish (4th January 2017)
The old man puts the knives on the dry part of the wet and dry grinder he has on the workshop but doesn't give a good edge see lots of burrs and pits in it.
I carry 1 of these and not had a problem with the blades at all;
https://www.ebay.com.au/itm/171562400828
"Never under estimate the power of the tap, let it flow through you"
www.swat4x4.com
Still think if you are processing a whole beast in the field then a decent steel would work.
Buy a decent Arkansas whetstone [soft] and create an edge which you can then maintain with the steel.
What size knife you use will determine what you need to maintain the edge.
Are you using butchers knives for example ???
That brought back some memories TD (good & bad), used to work in Abattoirs & Boning rooms back in the day. Used many F.Dick knives & a steel the same as this one rubbed down with 1200 wet & dry to near a smooth finish.
http://www.ebay.com.au/itm/Vintage-F...3D302176947737
Had a flat Victorinox steel as well. Couple of hits on it then a couple on the F.Dick. Could work the boning knives all day without having to put them on the stone.
Hi 3D I'm looking for a good skinner but I don't want to break the bank , have you got any suggestions
This is along the lines I'm thinking
http://www.ebay.com.au/itm/Gerber-MO...3D322272905168
Yea mate all is well just been busy with buisness and family, I'll be dressings a large buck if I can get close enough for a good shot with my bow. Got one of his antler from last year and it's longer then my arm. Looking forward to this .
