How much soot are we talking I've breifly looked over and haven't seen anything unusual. I'll upload a video of the manifold and what not and you can tell me what I'm missing.
Did anybody mention a warped EGR pipe at the back? Had that on my 3L CRD. It's common. But unsure if your older Di models have that pipe? @mudski ??
Fair enough. Mine was split right at the back in a bastard of a spot. And like OP's symptoms, only screeched it's head off above very specific PSI, which was around 12 or so from memory ...
Hodge (12th December 2016)
i meant the second one at the top,the black is slight,but it happens when the turbo boosts,plant the foot and you'd hear it...drive like a nanna nothing...take it somewhere and just tell them you think it's the manifold gasket,someone that fixes nissan they'll be straight onto it..
there is only a faint sign of black,but they diagnosed it straight up
Not much at all actually just enough till I can get it tuned by someone
How much is not much?
I think you are just hearing the sound of boost if you have an exhaust leak it going to be there regardless of the boost setting how ever if its a leaking IC you will hear it more as you up the boost
