Results 1 to 6 of 6
Thread: Drawers 2.0
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    Drawers 2.0
    Hello all.
    So, following on from my previous thread here Let-There-Be-Drawers ...
    I have spent some time reflecting on what needed improving following my last trip west and up the gulf. My first attempt at drawers was broadly successful but I needed to address a few issues in my quest for the perfect touring wagon.
    1. They were heavy. Very heavy. 12mm Ply wood just weighs too much. And I reckon is over engineered mostly. So I turned to Aluminium. Even though a lot of the weight is in the runners.
    2. Lack of light. It was a pain in the arse finding stuff in drawers this deep after dark with no moon.
    3. Safely securing the water tank - it worried the hell out of me that I could only attached 70Kg of water to bits of ply. In a prang I was going to be sorry!
    4. The switch panel. It was a pain to get to fuses and I didn't do near good enough a job on wiring this in.
    5. The water tap was a pain to get to - I had to slide the fridge in to use it.
    So. I designed Drawers 2.0....
    I made these from a 25mm Qubelok Aluminium frame with 4mm Marine play sheet and a 7mm top. All up weight came down far enough for me to add a 3rd battery in the back. The frame was 16kg. Pre runners.
    It also gave me a good frame to build restraints for the tank against. And I was able to make it square, because I suck as a carpenter.
    I added LED lights with auto-door actuators. I used cheap LED camping bars cut down with a drop saw. Works great.
    I moved the tap out into the barn door and added a tank level indicator.
    I was able to make a proper table between the drawers.
    These still have great storage in the wings - but the fuse block and water pump are both now easily accessible.
    Anyway - here is the result Drawers 2.0 .... I'm a lot happier. Anyone that wants drawings or details on building this let me know!
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  2. The Following 5 Users Say Thank You to Boinzo For This Useful Post:
    Bacho86 (7th December 2016), blocko05 (4th July 2017), Clunk (1st December 2016), threedogs (1st December 2016), Touses (1st December 2016)
    Beginner therepublicoftom's Avatar
    Dec 2016
    Redland Bay Area, Brisbane
    Boinzo, they look fantastic. I have a 13 GU and was looking to use similar materials.
    Dec 2015
    Brisbane
    Thanks! I'm really happy with it (now). Let me know if you would like my drawings and planning stuff... !
    Quote Originally Posted by therepublicoftom View Post
    Great use of the cargo area, Im not a fan of drawers,
    but yours look really good,,,, how much do they weigh???
    On the rear doors Ive fitted some alloy checker plate to
    protect them a bit, {400mm}
    Dec 2015
    Brisbane
    Thanks Threedogs.
    I'm not certain of the total, all up weight. But most of it is in the runners.
    The structure, with ply and carpet etc. is a bit over 20kg. But the runners are probably that much as well.
    Drawers aren't for everyone for sure. But I'm slowly making things work how I want...
    Apr 2017
    If you still have a problem with light, try a strip of self-adhesive LEDs at the top of the rear door. I mounted a strip of 12 LEDs under the top rear tail light so that any drawer that was opened would be lit from above. I wired it into the ceiling light so that I didn't need to add a new switch.
